Oil & Fuel fuel guage suddenly stopped working
   / fuel guage suddenly stopped working #1
beowulf
Central California Foothills
Kubota L3410 HST, J Deere riding mower
The fuel guage no longer works on my Kubota 3410. One day it worked and the next day it did not work. There is fuel in the tank. Any ideas or suggestions? I checked the fuse box and all are OK, unless there is an another fuse box somewhere.
   / fuel guage suddenly stopped working #2
Look for a broken or loose ground wire. Most fuel gages need a good ground to work.
Ron, I finally got around to popping the hood to check for the ground wire as you recommended. I found the problem. The wire from the top of the tank/sending unit was about 10" long and then it ended - connected to nothing. But that 10" wire didn't reach anything either so I did not know what it came undone from. After inspecting everything I could, I found another stub of wire, but between the two stubs was a gap of about 6-7 inches - of obviously missing wire. After additional poking around I found the chewed up sheath that covers the wires in the engine area. Then found the beginning of a critter's nest. So I patched in a new wire and guage works fine. The problem was one of nature's creatures. Now I will have to post somewhere on this forum a question about keeping critters out of your tractor. What I have done is to relocate our three cats to the barn where I keep the tractor - moved their houses and food and water to the barn loft and they seem to like it there so that might keep the mice or whatever away. Thanks for the advice - it was a "loose" wire - just very loose.
   / fuel guage suddenly stopped working #4
moth balls help,when its in storage
ALAN
   / fuel guage suddenly stopped working #5
Some D-CON might be helpful too. Help kill the mice/rats.
Curt
80in HD Tooth Bucket with Side Cutters ONE PER LOT (A52748)
80in HD Tooth...
NEW Wolverine Skid Steer Bucket Forks (A53002)
NEW Wolverine Skid...
John Deere 7520 (A50120)
John Deere 7520...
2018 Infiniti QX30 Premium SUV (A50324)
2018 Infiniti QX30...
Army Generator (A50774)
Army Generator...
2015 Kenworth T400 T/A Vactor 2100 Plus Combination Sewer Jetter Vacuum Truck (A50323)
2015 Kenworth T400...
