Oil & Fuel Fuel Gauge
   / Fuel Gauge #1
jbunkley
North Florida
2006 Branson 3510i
On my tc18 the fuel gauge is stuck at full. When the ignition is turned off
the needle goes to empty but goes back to full when turned on even tho
fuel is very low.
What should I check to correct this?
Thanks
   / Fuel Gauge #2
If it uses a float system.. can you peer in to see if it is actually stuck 'up'.
Soundguy
   / Fuel Gauge #4
My 24 was delivered w/ the problem you're describing. The solution was to snag the tank float w/ a wire hook to free it. IIRC the tech opened the tank (fill top) and inserted the hook toward the aft of the tractor along the its axis. I think if you gently feel around in the tank youll find the float easily enough. He left the hook in case the problem recurred, which it didnt. So not having done it myself I cant give better directions than this.
   / Fuel Gauge
Thanks for the replies...I will check out the float probe tomorrow.
Or should I say probing for the float.
2003 TRAIL KING TI-BROOK AFRM 40 - 40' DUMP TRL (A51406)
2003 TRAIL KING...
2010 Ford F-150 4x4 Pickup Truck (A51692)
2010 Ford F-150...
378711 (A51573)
378711 (A51573)
2022 John Deere 8RT 410 Tractor (A53342)
2022 John Deere...
Ryobi Sliding Miter Saw (A51573)
Ryobi Sliding...
