Fuel Gauge
/ Fuel Gauge #1
jtrentham
Mahindra 4025
I have a Mahindra 4025. Unsure of the year model because it was given to me when I bought the property. But the fuel gauge does not work but the rest of the gauge cluster will work. Possibly the gas tank level?
/ Fuel Gauge #2
It could be the gauge itself, the sending unit, or any wiring in between. You need to do a bit of troubleshooting. Does it always read full? Empty? Somewhere in between?
/ Fuel Gauge #3
Sender units are usually but a variable resistor that is actuated by a float on an arm.
The need 2 wires one of which is positive. Shorting the 2 should read 'full' at the gauge.
Often rust is often what renders the sender inoperative.
Early units often used cork as a float which could get waterlogged, more recent ones used plastic.
Often replacement calls for removing the tank for access in which case an alternate DIY is a calibrated dip stick.
/ Fuel Gauge
It reads empty all the time. Now I can’t get it to crank up because I believe I ran out of fuel. Any ideas of what needs to happen now?
/ Fuel Gauge #6
For those of us with older equipment and limited funds it's often easier to just check the tank.
My M4700 gauge is flaky. I try and fill it every 5 or 6 hours of use.
/ Fuel Gauge #7
I bought a gauge and sender for my old JD. I haven't installed it yet but I'm getting tired of the "dip stick" method. I had to drain the tank to install a new fuel screen and bowl so when I put 5 gallons back in it, I marked the stick.
I'm dragging my heels on the gauge install because I have to drill about a 2" hole in the top of the tank and the dash. The JD never had a gauge but I need to finish a couple of projects with it first.
/ Fuel Gauge #8
I have no idea how accurate the fuel gage is on my M6040. Use the tractor all day and it does show less fuel in the tank.
I have a habit. I fuel up the tractor after EVERY use. Never have to worry about running out. NEVER had water in my fuel either.
/ Fuel Gauge #9
^^ This
When I start a project, I want to jump on whatever I'm using, turn key and go. I don't want to have to fuel it, grease it.... so I try to do those things (don't always grease it) but I DO always top the fuel off.
Since I carry the 5-gallon jugs to the Co-op, this also lets me keep the machines full AND keep my reserve full. I don't have a bunch of empy machines laying around....need to do a job and gee....I don't have any diesel AND it's Sunday so the Co-op is closed....
Always top them off when done and then keep the 5-gallon buckets full (about eight of them) so I can work a full day and refuel the entire tank if/as needed.
Since I put a new wiring harness on the tractor, that gauge works fine. The gauge on the backhoe shows empty all the time (and I've fixed the sending unit in it once.....it died again so I've not touched it)
Knapheide Service Body w/ Ladder Rack (A62613)
Knapheide Service...
2022 C&W Gooseneck Trailer (A64047)
2022 C&W Gooseneck...
Arrow Quip 10' Heavy Duty Bow Gate (A64047)
Arrow Quip 10'...
2019 Chevrolet Silverado 2500HD Crew Cab Pickup Truck with Liftgate (A61573)
2019 Chevrolet...
2019 PETERBILT 579 6X4 T/A SLEEPER TRUCK TRACTOR (A59910)
2019 PETERBILT 579...
10ft Cattle Panels (A64047)
10ft Cattle Panels...
