Oil & Fuel Fuel filtr stuck
   / Fuel filtr stuck #1
czechsonofagun
Elite Member
Old Dominion
Kubota B1750
How do you unscrew the fuel filtr? I am not able to turn it - didnt try too hard yet, since the housing looks like zinc and I am afraid it is gonna brake.
Proly not a good idea to heat it up with a torch?:D :D
   / Fuel filtr stuck #2
Czech,
I do not know about your Kubota, but I am assuming you mean the housing so that you can get to the fuel filter?
But in either case I would try a strap wrench. Those are handy little tools to have around.
If that fails I like your heat idea, and depending on if your want a new house or shop do it inside and you can get new everything! Just make sure your insurance is paid up.
steve
   / Fuel filtr stuck
Yes, I mean the housing, should be simple, but it does not move a fraction of an inch.
   / Fuel filtr stuck #4
Ok.. Im going to ask a dumb question since I am not sure exactly how its made.. Are you turning it the correct direction??
I know when I take the oil filter off my truck 2002 Dodge w/ cummins - Im looking at the filter housing from the top and i have to think about which way im suppose to turn it to get it off. For some reason because im looking down on the filter I want to turn it the wrong way.
good luck
b
   / Fuel filtr stuck #5
Unscrews in a counter clockwise direction and yes they can be ungodly tight. I have twisted oil and fuel filters into pretzels before they were so tight. Can't say I have ever broken a filter housing.
   / Fuel filtr stuck
Thanks, I will give it more elbow power:) I just dont want to complicate my life by searching for new housing.
   / Fuel filtr stuck #7
If it's the factory installed filter they often are very tight. I think they have 800 pound gorilla's install them at the factory.
   / Fuel filtr stuck
Tractor has close to 1200 hours on it, I dont expect it to be the original, but you never know.
Gotta find some 800 monkey for me now:)
   / Fuel filtr stuck #9
Any pics? Most housings I've seen have a bolt running thru them (thinking Farmall oil filter housing). Are you saying you just have a housing shaped like a spin on filter, with the filter underneath that? The strap wrench sounds like a good idea, may need cheater pipe for that little "extra" persuasion (if you can't find your 800lb monkey).
2016 Ford Escape SUV (A50324)
2016 Ford Escape...
2012 MACK GU713 DUMP TRUCK (A51406)
2012 MACK GU713...
2003 Maverick Pathfinder 2200V Center Console Fishing Boat with T/A Boat Trailer (A50324)
2003 Maverick...
2011 Ford F-550 Iowa 1015 3,200LB Crane Mechanics Truck (A51692)
2011 Ford F-550...
2009 MACK GRANITE (A52472)
2009 MACK GRANITE...
2014 Doosan DA30 (A52748)
2014 Doosan DA30...
