Oil & Fuel Fuel FIlters
/ Fuel FIlters #1
1funride
My BX2200 has 170 hours and is 3 years old and I have not changed the fuel filters. I have done all other maint to the "T", and even have the filters, but just haven't done it. The tractor is stored inside. Seems like a waste to change them too often, may even be worse. From what I have been reading on this board they seem to collect moisture and that is why many have changed them. I can't image that they are that dirty. I was thinking of changing them at 200 hours. What are others doing??
/ Fuel FIlters #2
funny... the reason I opened this post is that I had the same psuedo-concern. I just flipped a hundred hours and have not done mine yet either. I use a fine screen funnel to take out large impurities and water. I figure next summer maybe I'll do them. (there's more than one isn't there?). Just seems like it will be a pain in the ...
/ Fuel FIlters #3
The fuel filters are positioned so they are easy to look in to see if you do have moisture building up in the bottom on most all Kubota tractors. It will start to look milky, water is heavier then fuel so it will go to the bottom. At three years I would say it would be time to change them. The filters normally do not all of a sudden stop working unless they get a good burst of water. They will slowly start Zapping the power away from the fuel starvation one horsepower at a time! You might never even notice the loss as it will be so gradual. I do recommend everyone to have a spare set on a shelf for that time when water gets in or more entertaining and frustrating, gas is accidentally added.
/ Fuel FIlters #4
Yes there are two the secondary is is easy to get to but the primary on the BX2200 is positioned so that You have to have the mmm deck off to change it.
It would have been nice if Kubota would have put a fuel shutoff inline from the tank to the primary filter ,but they didn't .
The clamp for the primary is awkward to loosen as well.
So Yes it is slightly mess to change them .
Seems like they run $8.75 each from Kubota.
Hope that helps some.
/ Fuel FIlters #5
put a piece of fuel line hose over each jaw of your needle nose vice grips and then clamp the rubber line to shut off the fuel flow. Works well and doesn't damage the rubber line. While you have it shut off, install a shutoff for the next time.... Junkman
/ Fuel FIlters #6
Junkman, I suppose you wouldn't shut that off more than once as an additional security device and forget to turn it back open before you start it, right?
/ Fuel FIlters #8
Not until the warranty runs out. /forums/images/graemlins/grin.gif
/ Fuel FIlters #9
I don't think that if you put an in-line valve in the fuel system that it in any way could invalidate the warranty any more than adding a rear light and strapping it onto the ROPS with duct tape or installing a tiny tach sensor module around the fuel line. The modification would have to effect the engine more directly before there would be any negative consequences.
/ Fuel FIlters #10
Maybe so ,but I am not a gambler....I have seen some pretty weird things happen ............. besides all it takes is one excuse if the wrong person is in the wrong mood.
So No Thanks I will stay with their add-ons until the warranty has said bye-bye /forums/images/graemlins/grin.gif
/ Fuel FIlters #11
If I wanted a fuel shutoff valve on my BX, I would install it, and would not be worried about it voiding the warranty. I also probably wouldn’t cut the original fuel line but add a short piece of line between the valve and the filter. That way if I decided for whatever reason (perhaps warranty concerns if my engine cratered /forums/images/graemlins/frown.gif) that I wanted it removed, all I would have to do is remove the valve and hook everything back like original. Problem solved.
I have been told a vehicle manufacturer cannot void a warranty because of a modification to a vehicle unless they can demonstrate that the modification was the cause of the failure. I guess if a company is looking for a reason not to honor their warranty, one excuse (like a fuel shutoff valve) is as good as another. /forums/images/graemlins/smirk.gif
/ Fuel FIlters #12
My experiences have always been that the extent of the warranty repair being accepted or rejected lies more with the dealership that is doing the repair than any other factor. It is rare that the factory representative inspects a vehicle before repair unless it is a major failure and the dealership request the inspection because there is some doubt in their mind if they will be reimbursed for the work after completion. I had a engine fail at 23K and the dealership tore down the entire engine in attempt to determine what caused the failure before the factory representative was called to inspected it. It turned out to be defective crankshaft casting that caused the failure and they replace the entire engine without hesitation.. They could have just as well rebuilt it, but the dealership felt that a replacement would be better for the customer (me) in the end result....
/ Fuel FIlters #13
I agree. The dealer is usually the judge of warranty claims unless he rules against you and you take it to a higher court (the factory). I believe that when it is not totally clear what caused the failure is when having bought locally has its greatest advantage. Since you are the dealer’s customer, he will want to rule in your favor if at all possible, whereas if you bought elsewhere he may not really want to do your warranty work and may look for a reason to deny your claim.
I have personally experienced this with a local car dealership that refused to do any warranty work on a new car that I bought from an out-of-town dealership until the factory representative forced them to. I know most dealers are not this extreme, but when a gray area comes up I believe your odds are always better with your purchasing dealer.
2004 53ft. Kingman Dry Van Trailer (A61573)
2004 53ft. Kingman...
2018 CATERPILLAR 232D SKID STEER (A64279)
2018 CATERPILLAR...
2016 Hyundai Sonata Sedan (A61574)
2016 Hyundai...
2025 JMR 78in Dual Cylinder Grapple Rock Bucket Skid Steer Attachment (A61572)
2025 JMR 78in Dual...
New/Unused CFG Industrial NT18K Mini Excavator (A65583)
New/Unused CFG...
1986 CATERPILLAR D4H HI-TRACK CRAWLER DOZER (A64279)
1986 CATERPILLAR...
