Oil & Fuel Fuel filters for a BX
   / Fuel filters for a BX #11
"I am getting a bio-diesel. I can't find any around here that isn't. It just says on the pump that it is between 5% and 20% blend."
Dodge Man,
I'm not sure where you are in central IL., but I've been buying all my fuel from the truck stop at the corner of IL-104 and Interstate 55 for over 20 years. I know they blend it for winter and I also add power service anti-gel. I don't think they sell bio in the winter. Check them out if you're close.
kj
I'm located in Macomb, Illinois, which is a pretty good distance from where you are. I'm buying my fuel from places that would appear to have pretty good turnover in fuel. One place I usually get it is the only place setup to fuel the big rigs in town. I tend to think the fuel is gelling but I'm not sure. I'll just try adding more anti-gell stuff.
   / Fuel filters for a BX #13
Yes bio-diesel does gell when in the 20's. We have has several VW diesel owners car who run the homemade bio die during this cold winter weather. I find that the screen in the fuel tank along with the filter is plugged. I have read that some start the engine on regular diesel and once warm switch over to the bio. They have installed a coolant feed fuel heater. Were're lucky as the bio isn't at the pumps yet.
   / Fuel filters for a BX #14
For the amount of fuel I consume in a year I run on road diesel. ( 50 - 75 gallons ) Mostly because it's always available a mile from my house. I ran heating oil a few times in a pinch and it smells awful and gives me a headacheif I run the tractor for a while.
Adding anti gel will help, just a thought do you keep your tank mostly topped off? I'm not sure how much the tank would condensate as its a fairly closed system but......
I usually add some Centane (??)Octane Boost with an antigel agent to the can when I fill up, available at Wally Mart.
   / Fuel filters for a BX #15
Ugh. :(:( Bio juice in diesel and ethanol in gas. I know the politicos that be think all this stuff is nifty, but I just wish there was some freedom of choice in these matters. Just an old fashioned pure fuel kinda guy myself.
   / Fuel filters for a BX #16
I changed my fuel filters at 50 hours (now 134 hr) and still run fuel from August 09 in MA...runs fine.
:confused:Several of the posts refer to "fuel filters". Is there more than one fuel filter on the BX2660? I only see one plastic fuel filter and one gizmo that is metal and is called the "fuel pump" in my Operators Manual.:confused:
   / Fuel filters for a BX #17
My 50 hr. kit came with 2 fuel filters, indeed.
   / Fuel filters for a BX #18
:)Thanks BP. If the wind chill wasn't at zero here, i'd go out and look; but, repeat, the manual on pg 50 calls the rear plastic filter a "fuel filter"....it calls the metal gizmo downstream from it a "fuel pump". So, where is the other fuel filter that is plastic?:confused:
   / Fuel filters for a BX #19
One is by the engine near the pump and one is back between the lift pump and fuel tank
MARATHON 20KW GENERATOR (A58214)
MARATHON 20KW...
2006 Mercedes-Benz (A55758)
2006 Mercedes-Benz...
2009 Ford F-250 4x4 Ext. Cab Pickup Truck (A56858)
2009 Ford F-250...
More info coming soon! (A55851)
More info coming...
2017 WEILER P385 ASPHALT PAVER (A52709)
2017 WEILER P385...
John Deere 5103 (A53317)
John Deere 5103...
