Oil & Fuel Fuel Filter slow filling
   / Fuel Filter slow filling #11
There is ableed screw just in front of the injector lines on the injection pump.
This will bleed the filter and the pump.
_________________________________________
For all of your Parts, oils, and filter needs go to partspring.com and get your parts there or call !-888-772-7414.
Class III TC's don't have a dedicated bleed screw on the pump. What used to be a bleed screw is now a banjo bolt to accommodate the injector return flow. Completely bleeding the filter head is sufficient for a filter change without complications.
   / Fuel Filter slow filling #12
I do not know what kind of tractor you have.......but recently when I changed my diesel filter and cleaned the bowl on my JD 770......when I turned the shutoff valve back on line and drove away the bowl would fill very slowly and only fill halfway. Upon closer inspection the seating screw that holds the lever in the shutoff valve had slipped therefore the valve showed open but was choked off. It came apart real easy and the realignment took only a few minutes and all was well after that!:D
JD 770 / 70 FEL / 7 BH - 425 AWS / 54" MMM / 54" FMP
What are you going to carry? What are you going to ditch? What is important in your life!
1992 DFI PULL SPREADER (A57192)
1992 DFI PULL...
(INOP) RHINO 1310 ROTARY CUTTER (A52708)
(INOP) RHINO 1310...
2021 Chevrolet Silverado 1500 4x4 Crew Cab Pickup Truck (A56858)
2021 Chevrolet...
2015 Chrysler 200 Sedan (A56859)
2015 Chrysler 200...
2017 Dodge Charger Sedan (A56859)
2017 Dodge Charger...
2013 Land Rover Range Rover Sport 4X4 SUV (A55853)
2013 Land Rover...
