Oil & Fuel Fuel Filter Selection
/ Fuel Filter Selection #1
robertm
Northern Illinois
Kubota BX2660
How do I choose a Racor fuel filter and separator for my BX2660? I despise the barbed plastic lawn mower type Kubota uses. A bowl-type or spin-on would be easier to maintain and thaw if gelled up.
Help is appreciated.
While it is not a Racor I am working on mounting the Kubota filter and water separator that is used on some of the B series, the new RTVs, on my BX2230. Think I can get it on a bracket in front of the injector pump on the left side of the D902 engine, not sure how much room you have. Kubota Fuel Filter Assy Part #6A320-58862 David
That's it! That's what I wanted all along. $20 seems cheap. I'm gonna order for my spring project. Thanks!
/ Fuel Filter Selection #4
What is a typical micron rating for a diesel fuel filter, if that is the only one in the system? You know, I did a search for specs and only got the outer sizes of the filter, not the micron rating or the pipe size. Some specs!
/ Fuel Filter Selection #5
It may not interest you but I have a Dahl 75 filter plumbed as the primary filter on my L3000. it's rated for up to 90 hp and the elements I'm using at this time are 2 micron rated. In almost 1400 hrs I have only changed my factory filter 3 times. One of those was because I dumped water in the tank from a dirty jug. The other 2 times the factory filter was not clogged or causing any problem I just changed it just because of the amount of hrs in service. I bought mine from Amsoil but they since have dropped the Dahl line. I don't know who all does sell them but they are listed in the Baldwin filter catalog.
36in AIM Bucket w/ Teeth Excavator Attachment (A64194)
36in AIM Bucket w/...
Bainbridge,Georgia (A65640)
Bainbridge,Georgia...
213101 (A64276)
213101 (A64276)
Caterpillar 70in Loader Forks and Frame Attachment (A61572)
Caterpillar 70in...
2016 Kubota RTV X1140 (A65563)
2016 Kubota RTV...
2013 Hyundai Volster Coupe (A59231)
2013 Hyundai...
