Fuel filter replacement
/ Fuel filter replacement #1
ancote
I did replace the fuel filter, start the engine and it die after 5 minutes.:confused:
It wont start no more, just cranking :(
What could be the problem ? :rolleyes:
/ Fuel filter replacement #3
Welcome to TBN!
Is it a diesel engine? If it is........
Did you fill the new filter with fuel before installing, even if it is self-bleeding?
Did you make sure there is fuel in the tank?
Did you turn the fuel line valve to the "OFF" position?
/ Fuel filter replacement #4
If it's a diesel engine then the fuel system is probably air bound. You need to bleed the injector lines to remove the air from the system. Crack the lines open at the injectors and crank the engine over until you see fuel squirting out, tighten the lines up and it should start.
/ Fuel filter replacement #5
G'day as dieselpower said if it is a diesel then it will need to be bled but it may need to be bled at the filter and pump first if you are not sure how to do this tell us what sort of machine it is and someone may be able to give you step by step instructions:)
Jon
2005 Suzuki King Quad 700 Fourwheeler (A61166)
2005 Suzuki King...
2013 International WorkStar 7400 4x4 Altec AM547 50ft Material Handling Bucket Truck (A61568)
2013 International...
2015 CATERPILLAR 305E2 CR EXCAVATOR (A62129)
2015 CATERPILLAR...
UNUSED KUBOTA 12" PIN ON EXCAVATOR BKT (A62130)
UNUSED KUBOTA 12"...
2023 John Deere 9RX 540 Track Tractor (A63109)
2023 John Deere...
Thomasville,Georgia (A63116)
Thomasville,Georgia...
