Fuel Filter Maintenance for L3200
   / Fuel Filter Maintenance for L3200 #1
wlollar
Ethelsville, AL
Kubota L3200
I have an L3200 and recently changed oil and the oil, fuel and air filters. I found a 'how to' video on YouTube showing oil change on a L3200, but I can find no information on the fuel filter. My question is, when I got the new filter at the dealership, it was just the filter, no O-ring. When I took the bowl off, the old O-ring was there and intact but I didn't pay close enough attention as to whether it was seated on the old filter or just laying there. When I installed the new filter, I wasn't quite sure if it was just to lay on top of the filter or what. Also, is that the only O-ring or did I miss one on the old filter? For reference, the filter part # is 6A320-59930. Any help would be appreciated.
   / Fuel Filter Maintenance for L3200 #2
There might be two o rings, one on the clear cover and another for the center. At least that’s what my 3350 has. The larger o ring is sold separately.
   / Fuel Filter Maintenance for L3200 #3
This might help you... When I changed my filter, my small little "O" ring stayed on the old filter and the new one was leaking. Easy to fixed.
   / Fuel Filter Maintenance for L3200 #4
2 o rings a small one and a big one is correct:) need part numbers?
The filter I have has the plastic top housing molded onto the paper element... for reference. It didn't come with any O-rings when I bought it. I used the large O-ring from the old filter, but I didn't notice a smaller O-ring on the old filter.
Part #s would be great. Can you give me details as to where exactly the O-rings go on the filter. When I removed the old filter, the large O-ring seemed to just be laying on top of the plastic housing. I didn't see a small O-ring and the parts guy offered/included ANY O-rings. I just want to make sure I have proper placement of the O-rings. Thanks!
   / Fuel Filter Maintenance for L3200 #8
I would go back and buy the o-rings. It's a good idea to replace them at the same time as the fuel filter. They get stiff over time, and don't necessarily reseat properly when reused.
   / Fuel Filter Maintenance for L3200 #9
kub 6A320-59940, o-ring 6A320-59950 o-ring , 6A320-59930 fuel filter, post #3 shows the picture
   / Fuel Filter Maintenance for L3200 #10
Selling a filter w/o the orings is "cheezy"..
Just like selling a supply pump w/o a gasket or a thermostat w/o a gasket..
You guys ever had to replace a thermostat & they DIDNT HAVE a gasket IN STOCK?? Happens ALL THE TIME..
an .89 cent gasket!!! holds up the entire job..
sorry, got off track.
2015 FORD F-150XL SINGLE CAB TRUCK (A51406)
2015 FORD F-150XL...
Gravelly Pro-Turn 148 48in Zero Turn Mower (A48082)
Gravelly Pro-Turn...
2016 Ford Explorer AWD SUV (A50324)
2016 Ford Explorer...
JOHN DEERE 250 SKID STEER (A51242)
JOHN DEERE 250...
2017 Dodge Grand Caravan SE Van (A50324)
2017 Dodge Grand...
Tandem Axle Silage Cart (A50774)
Tandem Axle Silage...
