Oil & Fuel Fuel filter change...HOW?dk45s
/ Fuel filter change...HOW?dk45s #1
fiddleback
Stafford CT
2006 Kioti DK 45s
This Post is kind of a continuation to an earlier post that got off topic real quick. The manual is unclear to me and I think the diagram (picture) might be wrong as well, so, I know where the fuel filter is, What next,please be specific? (not rediculously, just a step by step format if possible) Thanks, Tom
/ Fuel filter change...HOW?dk45s #2
1. shut off fuel
2. take fuel bowl & locking collar off, be sure not to misplace the spring in the bottom of bowl.
3. swap out filters
4. install bowl and locking collar most of the way - leave slightly loose.
5. turn on fuel, when bowl is full of fuel, tighten locking collar.
6. crank engine over, I try not to start it(but cycle fuel pump)..... crack air bleed screw to get out remaining air.
perfect, i'll print that! Thanks Tom
/ Fuel filter change...HOW?dk45s #4
Doesn't the DK45s have a spin on cartridge? no fuel bowl on this model, and you have the wire to disconnect.
Mainly just unplug wire... un screw fill and replace... I also think there is a shutoff.
/ Fuel filter change...HOW?dk45s #5
Hi,
If you have a DK45S it has a cartridge filter(like the oil filter) It is on the right side(sitting on tractor) and unscrews like the oil filter. It is a good practice to fill the new filter with fuel before you screw it on so you don't have to pump as much fuel to fill the system again. Remember to turn your fuel off and then back onafter replacement.
KiotiDave
OK,ok folks. I do appreciate all the replies, but I gotta admit, there seems to be a vast amount of different cartridge,bowls,shutoffs,turn ons,bleeders for air, and last of all priming pumps. I'm sure you all know how to change YOUR fuel filters, but few of you, if any know perfectly how to change mine. And what the heck is with the WIRE to unplug? I'll be danged if I can find one! I am going to try to perform this task this weekend and when I get her started again. I'll post pics with a step by step and maybe someone can benefit in the future.
That said, this is what I have.1 A replacement cartridge ( at $20) why clean anything? Is that even smart? 2 A bleeder valve (actually its a thumb screw on the filter ***'y) 3 A priming pump that stands "dead zero" on top of the filter ***'y.
This is my course.... Unscrew old filter, dispose of it, screw on new filter AFTER I have filled it with fuel, Open bleeder valve, press on priming valve until fuel exits both the bleeder screw and the overflow setup on the bottom of the new filter (i'll take one or the other if I have too). Then I'll try and start, when it fires up turn the rpm's a little high until all air is out of the system. Then i'll wash my hands...... TOM
oh yeah, Avatars are hard to downsize small enough to make it out! All I have is paint.net, which has worked well up to this point. My apologies, i'll change back to nothing when:mad: I get a chance....ticks me off
/ Fuel filter change...HOW?dk45s #8
Sorry I was thinking of the DK55 tractors. They have a wire on the bottom of them.
2001 Belshe Backhoe Trailer (A64194)
2001 Belshe...
1969 VOLKSWAGEN BUG (A59905)
1969 VOLKSWAGEN...
2019 ALLMAND LIGHT PLANT (A65643)
2019 ALLMAND LIGHT...
3 POINT BEAR CAT 71854 WOOD CHIPPER (A65643)
3 POINT BEAR CAT...
Freightliner Tender Truck - Adams Tender (A63688)
Freightliner...
8' DISC HARROW (A60430)
8' DISC HARROW...
