Oil & Fuel Fuel Filter Change BX2230
   / Fuel Filter Change BX2230 #1
pondrosa
Can anyone give me instructions on changing both fuel filters on a bx2230?
The shut off solenoid should keep fuel from leaking when I change the one in the engine compartment
The filter between the tank and the solenoid is the one I'm worried about:cool:
Tom
   / Fuel Filter Change BX2230 #3
Use vice grips to crimp the fuel line.
   / Fuel Filter Change BX2230 #4
Tom
Easy, remove filter and install new one..Do not bother crimping line. You will lose about 4 oz fuel...It will start right up..
   / Fuel Filter Change BX2230 #5
Tom
The fuel solenoid will not keep the fuel from leaking. It only energizes for a few seconds to shut down the fuel rack in the pump to kill the engine.
David Kb7uns
   / Fuel Filter Change BX2230 #6
How do you get to the filter that is close to the fuel tank?
   / Fuel Filter Change BX2230 #7
There are 2 filters. One up by the injector pump, the other just inline ahead of the electric pump. To get to the one ahead of the pump, pull off your mower if you have one, and crawl underneath. There is no filter up by the tank itself.
2017 Ford F-550 Ext. Cab Valve Maintenance Truck (A50323)
2017 Ford F-550...
2018 Dodge Charger Sedan (A50324)
2018 Dodge Charger...
2015 Jeep Compass SUV (A50324)
2015 Jeep Compass...
2006 MACK CV (GRANITE) BOB TAIL KILL TRUCK (A50854)
2006 MACK CV...
2018 MDB T5E MDB DISC MOWER (A51243)
2018 MDB T5E MDB...
PLEASE CHECK BACK!!! ITEMS BEING ADDED DAILY!!!! (A50775)
PLEASE CHECK...
