Fuel filter bowl - No warning??
/ Fuel filter bowl - No warning?? #1
Jay4200
Veteran Member
Hudson/Weare, NH
L4200GST w/ LA680 & BX2200D w/ LA211
I FINALLY changed my fuel filter yesterday - I bought the filter/o-rings when I got the tractor in 2005, but never got around to changing it - call it a 500 hour procrastination...not bad.
It went smooth, although I couldn't get the little o-ring off - need a pick or something - so I didn't change it. Thanks all for the advice on the locking ring.
HOWEVER - nobody warned me about the 1/2 gallon or better of diesel that came shooting out of the tractor after I pulled the filter! Where did all that come from?? It poured out like a 15 y/o-prostate pee for at least a minute before it even started to slow down. Thank gawd I just happened to drop a decent-sized drain pan under the filter before popping the cover.
After dumping all that fuel out (and assuming that it all came from somewhere between the filter and the injectors), I figured there was no way my tractor would start back up. It cranked instantly - no clue where it got the fuel - and didn't cough or sputter once during the 30-seconds with the air valve open. I don't think it even needed the air bleed.
If I had known THAT much fuel was going to dump out, I would've had a fuel can standing by, and I would've dumped it right back into the tractor. At is was, I caught a couple of cups in a can, but used to to flush the crud out of the fuel bowl.
JayC
/ Fuel filter bowl - No warning?? #2
Mechanic at local dealer says he clamps fuel feed line hose when changing fuel filter on B2320. Guess that's the reason <g!>.
/ Fuel filter bowl - No warning?? #3
I only lose a very small amount out of mine. I don't do anything other than shut the fuel valve.
FORD 3 BOTTOM PLOW (A64278)
FORD 3 BOTTOM PLOW...
2021 MOROOKA MST2200VDR TRACKED DUMPER (A65053)
2021 MOROOKA...
2019 Chevrolet Malibu Sedan (A64557)
2019 Chevrolet...
2018 Dodge Charger Sedan (A64557)
2018 Dodge Charger...
Club Car Emergency Cart (A64557)
Club Car Emergency...
John Deere 544K Articulated Wheel Loader (A64553)
John Deere 544K...
