fuel filter 2816
/ fuel filter 2816 #1
irishrover
Sandy, Oregon
Mahindra 2816 Ford 8n
I have a 2816 4x4. Great little tractor, but that fuel filter sure is small. I carry extras in the tool box so I can do a quick field replacement when necessary. I'm past the five year warranty so I was thinking about installing a larger filter or adding an additional filter. I uses off road diesel and make sure I buy clean fuel. It's just with a lot of work that small filter has a big job to do.
/ fuel filter 2816 #2
The newer models have a "pre filter" filter. Sounds like what you are trying to install. I'd put it low (that's what the factory did) and use a cartridge style which are cheap and can be inspected.
Dutton-Lainson Goldenrod 495 Fuel Filter - For Life Out Here
You will want a shutoff between the tank and this so you can change the filter without losing all the fuel in your tank.
/ fuel filter 2816
Thanks for the information. That is just what I had in mind.
/ fuel filter 2816 #4
I don't understand why you're having problems with dirt filled filters. I have the 3016 which I'm sure is the same engine as yours, and when I change my filter at the hundred hour mark, it looks almost as clean as when new. There is no 'pre filter'. I'm very suspicious of your fuel.
/ fuel filter 2816
I'll look around for another source of off road fuel and se if that helps. Thanks
2012 FORD E-350 CUTAWAY SERVICE BODY TRUCK (A59912)
2012 FORD E-350...
2018 Infiniti Q60 AWD Coupe (A61574)
2018 Infiniti Q60...
Location (A63117)
Location (A63117)
2015 Ford Transit 250 Cargo Van (A61573)
2015 Ford Transit...
2023 Unverferth 3PT 10 FT Perfecta Field Cultivator (A63688)
2023 Unverferth...
MF GC2300 fel replaced
