fuel filter 2816
   / fuel filter 2816 #1
irishrover
Sandy, Oregon
Mahindra 2816 Ford 8n
I have a 2816 4x4. Great little tractor, but that fuel filter sure is small. I carry extras in the tool box so I can do a quick field replacement when necessary. I'm past the five year warranty so I was thinking about installing a larger filter or adding an additional filter. I uses off road diesel and make sure I buy clean fuel. It's just with a lot of work that small filter has a big job to do.
   / fuel filter 2816 #2
The newer models have a "pre filter" filter. Sounds like what you are trying to install. I'd put it low (that's what the factory did) and use a cartridge style which are cheap and can be inspected.
Dutton-Lainson Goldenrod 495 Fuel Filter - For Life Out Here
You will want a shutoff between the tank and this so you can change the filter without losing all the fuel in your tank.
   / fuel filter 2816
Thanks for the information. That is just what I had in mind.
   / fuel filter 2816 #4
I don't understand why you're having problems with dirt filled filters. I have the 3016 which I'm sure is the same engine as yours, and when I change my filter at the hundred hour mark, it looks almost as clean as when new. There is no 'pre filter'. I'm very suspicious of your fuel.
   / fuel filter 2816
I'll look around for another source of off road fuel and se if that helps. Thanks
2018 Nissan Sentra Passenger Car (A51694)
2018 Nissan Sentra...
2015 Crane Carrier Co. Low Entry (LE2/LD2/LW2/LT2/ST2/SD2) Truck (A51692)
2015 Crane Carrier...
Marliss Industries Grain and Soybean Drill - Selling ABSOLUTE NO RESERVE (A52748)
Marliss Industries...
2015 HINO BOX TRUCK (A52472)
2015 HINO BOX...
2012 INTERNATIONAL WORKSTAR 7500 (A52472)
2012 INTERNATIONAL...
2016 Kubota RTV-X900 4x4 Utility Cart (A51691)
2016 Kubota...
