Oil & Fuel Fuel cap gasket fell into tank. Now what?
   / Fuel cap gasket fell into tank. Now what? #1
FrontEndLoader
I have a Kubota 7510 HST. The gasket separated from the fuel tank cap and fell into the fuel tank. Arghh. I'm assuming that sooner or later it will block the flow of fuel to the engine. How can I get it out?
   / Fuel cap gasket fell into tank. Now what? #2
Coat hanger???
   / Fuel cap gasket fell into tank. Now what? #3
Coat hanger???
Plus a flashlight and lots of patience. :D
If you run the tank low on fuel it may be a lot easier to see and snag.:D
   / Fuel cap gasket fell into tank. Now what? #4
on my 4330 the gas cap is offset substantially from the fuel outlet on the tank and you'd have to be a lucky contortionist to fish it out if it was actually blocking the flow (of course, you could fill the tank with mercury and it would float)
   / Fuel cap gasket fell into tank. Now what? #5
Plan A-Try a coat hanger.
Plan B-Get a new gasket and dont sweat it.
I have had a gasket in a dump truck fuel tank for years with no problem.
   / Fuel cap gasket fell into tank. Now what? #7
You can get one of those flexible retrieval tools from Sears. That might work..
   / Fuel cap gasket fell into tank. Now what? #8
I doubt it will ever give you any problems. The fuel flow rate is so low it would have to wrap itself around the outlet to have any effect at all.
There is probably a strainer of sorts over the outlet, it may even be a raised pipe in the tank, possible to damage it if you fish around too much with a coat hanger.
Unless it actually gives you grief, I'd just forget about it.
Chilly
   / Fuel cap gasket fell into tank. Now what? #9
I'd just run the level down as low as needed ( drain tank ) ? Then, take a coat hanger, put a small hook in it, grab a mini mag light, and go fishin' !:)
   / Fuel cap gasket fell into tank. Now what? #10
If you are really concerned and can't get it using any of the aforementioned techniques, drain the tank turn it off and get the gasket out more easily.
JOHN DEERE 648R LOT NUMBER 108 (A53084)
JOHN DEERE 648R...
2023 JACTO JATAO-1000 LOT NUMBER 70 (A53084)
2023 JACTO...
2020 GENIE TZ-34/20 TOWABLE MANLIFT (A51242)
2020 GENIE...
2000 Toyota Tacoma Pickup Truck, VIN # 5TEWN72N6YZ690085 (A51572)
2000 Toyota Tacoma...
