Fuel can filter for diesel?
   / Fuel can filter for diesel? #11
Are they that good?
I read somewhere that a common problem with them is the seal leaking around the threaded nozzle ring whenever you have the button pushed and fuel is coming out.
I can't those fuel cans anywhere in Canada, so I would have to get it sent to my post office at the border and go pick it up.
I was looking for one myself.
Apparently they are not legal in Canada. Vessey's seeds was going to carry them as part of the Mantis tiller line I think, so I stopped in when I was in PEI to get one. I was told they had to send them back due to them being unapproved. That was last year so maybe things have changed.
   / Fuel can filter for diesel? #12
Are they that good?
Well I can see room for improvement, but the nospill are all that I use any more. Are they perfect? no, but pretty sweet. I'd like to see a see a separate fill cap so the spout can remain in place. What I do is when I fill the cans I turn them upside down briefly to be sure that the oring is seated. I have 4 of the 2.5 gallon cans, two 1.25 gallon and one 5 gallon gas plus one 5 gallon diesel. I gave one of the 2.5 gallon cans to my brother. I don't use my cans too often, but when I do they work quite well and I don't stink like gas. I have an old can with the spout stored inside and I always stink like gas when I use that one.
I have my own 575 gallon diesel tank so I seldom use the diesel can, but it is here if I need it.
These cans are good enough that they get a Honda oficial part number in fact my 5 callon can came with a Honda sticker on it.
   / Fuel can filter for diesel? #13
I got a Honda labeled one for my chain saws. I love it and have had no problems. I never overflow the saws now.
   / Fuel can filter for diesel? #14
I bought a diltered funnel fron CDN Tire, has a shut off on the bottom. Buy diesel from a busy truck stop and run conditioner year round. Also change fuel filter annually. Have zero troubles.
   / Fuel can filter for diesel? #15
Hiya,
If you want to make sure you filter the fuel, get a deep funnel and stick a automotive paint strainer in it, pour through the strainer and your good. They will catch just about anything and they will also plug very quick if you have clouding/jelling or any alge. If you plug the strainer, you have a fuel issue.
Tom
2001 CATERPILLAR IT28G (A52472)
2001 CATERPILLAR...
2018 Wacker Neuson RTSC3 Trench Compactor (A54865)
2018 Wacker Neuson...
2017 FREIGHTLINER M2 106 (A53843)
2017 FREIGHTLINER...
2016 Toyota Prius Hatchback (A55758)
2016 Toyota Prius...
New/Unused Easy Clean Hot Water Pressure Washer (A54865)
New/Unused Easy...
UNUSED RAYTREE RMSG29 - 29" STUMP GRINDER (A54757)
UNUSED RAYTREE...
