Fuel Caddy?
   / Fuel Caddy? #41
I'm considering a fuel caddy for the bed of a pickup. I'd like to get a smaller one so I can go get fuel and then use the bucket of my tractor to lift it out of the truck and store in my barn. Right now I use 5 gallon jugs and I'm getting tired of that, small spills, heavy jugs, junk in the fuel/jugs etc. Plus I like the idea of the fuel going through another filter.
Any suggestion on what to get without breaking the bank? I could get by with a non-electric pump but then I wouldn't be able to see when my tractor is almost full (fill cap is on top of the tractor, ugh). So I'm guessing I'd need a 12V pump and filter as well.
I have a Kubota B3200 and I think my bucket is limited to 1,000 pounds, so with diesel at 7.1lbs per gallon + fuel caddy....
Delta has a 50 gallon square one. I purchased it at farm and fleet for 179.$ i mounted it to a pallett and use my endloader forks to put it in my turck to refill it. When it full I set it on another pallett on casters and roll it around the barn. this with a roatery pump works like a charm.
   / Fuel Caddy? #42
I guess I'm old school. I don't use auto shutoff nozzles. I don't trust myself enough for those. I want to be there watching the tank fill. I have taught myself to let go of the handle before it runs over. I frequently pump 50 gallons or more at a time. Sometimes as much as 100 gallons.
   / Fuel Caddy? #43
This may raise some eyebrows but I built my own. I welded 1/8" steel sheet to form a 20 gal "box" complete with lift tang, wheels, vent, filler neck, grounding strap, handle and built-in hand pump. I leak tested it by filling with water to the top of a temporary extended filler neck and pressurizing to 60 psi. Hung it for 24 hrs and observed a few leaks which I re-welded. I repeated the leak test once and got no leaks. That was 10 years ago. All I would do differently now if I was to make another one is add a drain plug.
2021 CATERPILLAR D3 LGP CRAWLER DOZER (A51242)
2021 CATERPILLAR...
2007 Chrysler 300 Sedan (A50324)
2007 Chrysler 300...
John Deere 4020 Tractor (A50514)
John Deere 4020...
New 4x6 Chicken Coop (A50774)
New 4x6 Chicken...
2018 FORD F-550 (A50323)
2018 FORD F-550...
1996 MEC 2548 ELECTRIC MANLIFT (A51242)
1996 MEC 2548...
