Fuel bowl plastic shrinking?
   / Fuel bowl plastic shrinking? #1
repete
Veteran Member
SW Washington
L2550DT IH584-4WD
My neighbor just can by with his plastic fuel filter bowl and the threads and shrunk to the point they look like a pipe thread and it will no longer screw in and seal. I am guessing it to be about a 25 horsepower unit and 2.5 years old.
Is this a common thing?
   / Fuel bowl plastic shrinking? #2
Did he cross thread it and wreck the threads. Some have a o-ring seal also....
   / Fuel bowl plastic shrinking? #3
I also had that problem on a Mitsubishi K3 engine.
Bowl is real close to the engine and my take heat did it in.
Mine was very dark yellow* age tinted as well as shrunken.
While it still threaded on OK, filters no longer would fit in.
Only replacement bowls available were 3 " long but I had to have a shorter 2" one.
I cut a 3" back to 2", capped and sealed it and added a drain cock making it into a separator.
I next added an inline throw away filter for any fines'
Going on about 5 years now and all is fine.
ps; tried some 5-6 different brand dealers to attempt to locate my proper 2" bowl without satisfaction.
* yellow was age related and not from rust.
No, it is the total circumference of the thread. At the end with the O ring seal it is like 4" and at the distant end of the thread from the O ring it is like 3 3/4". Looks like the taper to a pipe thread.
Adams 6T Fertilizer Spreader (A53473)
Adams 6T...
2020 Kubota MX5400 (A50123)
2020 Kubota MX5400...
2009 KENWORTH T6 SERIES SLEEPER (A53426)
2009 KENWORTH T6...
2015 Nissan Sentra Sedan (A53117)
2015 Nissan Sentra...
2025 KG43 UNUSED Chain and Ratchet Binder Set (A53117)
2025 KG43 UNUSED...
2020 Utility Trailer Manufacturing, 53' Trailer (A52384)
2020 Utility...
