Oil & Fuel Fuel bowl o-ring leaks YM2210D
   / Fuel bowl o-ring leaks YM2210D #1
souperbee
Melrose/Grandin/FL.
Yanmar YM2210D
Question has anyone been having trouble with their fuel bowl leaking at the o-ring? This is my 3rd o-ring in 2 months. I don't know if it is the heat or what? I live in Florida and it has been super hot. I don't see any cracks or any imperfections on the housing. Did anyone switch over to a glass fuel bowl instead of the plastic one? Any comments would be greatly appreciated.
   / Fuel bowl o-ring leaks YM2210D #2
Are you using the correct O-ring.
Danny
I purchased the o-rings from 2 different companies. So I would think they are right.:rolleyes:
   / Fuel bowl o-ring leaks YM2210D #4
Might you be using a ethanol blend gas? Some rubber compounds don't react to well with ethanol. You might try getting a Viton or EPDM compound rubber O-Ring instead of the old Buna-N type.
If the O-Ring you have is round (the cross section that is) you might try getting a square cut O-Ring. It will have a much greater sealing surface than the round type.
(If the O-Ring you have is round (the cross section that is) you might try getting a square cut O-Ring. It will have a much greater sealing surface than the round type.)
Diesel Power, thanks for the info I will try a square ring. As far as the your other reply it uses Diesel fuel. Now I am wondering if there is a difference in orings for gas or diesel?
   / Fuel bowl o-ring leaks YM2210D #6
souperbee said:
has anyone been having trouble with their fuel bowl leaking at the o-ring? This is my 3rd o-ring in 2 months ... I purchased the o-rings from 2 different companies. So I would think they are right.
This is a long shot, but are you installing it in the right place?
The o-ring rests on that outside shoulder that is near the top of the bowl - not at the extreme top of the bowl, and not beneath the shoulder.
If that's not it, could the leak instead be from the seal for the on/off lever?
California, I believe I am installing it right, also when I purchased the tractor a little over 2 months ago. The dealer installed the first o-ring because I spotted it leaking. I replaced 2 after him. It takes maybe 2 to 2 1/2 weeks before it starts leaking after replacement. I thought vibration was the problem but the ring is tight when I check it. This thing sure has me scratching my bald head!:eek:
   / Fuel bowl o-ring leaks YM2210D #8
Fuel filter may be incorrect size. I had one that was a little longer than the original one, ended up causing a hairline crack in the clear type bowl right at the base of the lip. Part number 11 would hide this from visual inspection. With a longer filter you may not be able to torque it enough for a good seal. If the filter, o-ring, bowl are correct and both mating surfaces are smooth and clear of debris then you may just need to put a little more muscle behind the wrench.
VT_Hokie, thanks for the suggestion. I will check it out tomorrow. I want to Thank All for all the good suggestions. This is sure one knowledgeable group. Thanks All
   / Fuel bowl o-ring leaks YM2210D #10
I had this same trouble! I was told on this forum that those fuel bowls shrink over time. I ordered a new fuel bowl. I think from Hoye? Any way that is what u need. The old one was clear hard plastic and the new one is a softer cloudy plastic but it has been great for about 2 years.
American Farmworks 15 Mile Fence Controller (A51573)
American Farmworks...
2019 Caterpillar 299D2 High Flow Compact Track Loader Skid Steer (A51691)
2019 Caterpillar...
(3) 55-Gallon Drums of Fertilizer (A51573)
(3) 55-Gallon...
INOP/NON-RUNNING 1999 International F-2574 Fuel Lube Truck, VIN # 1HTGGATT4XH682675 (A51572)
INOP/NON-RUNNING...
40ft High Cube Shipping Container (A51573)
40ft High Cube...
New Land Honor Heavy Duty Plate Compactor (A53002)
New Land Honor...
