Oil & Fuel Fuel bowl o-ring leaks YM2210D
   / Fuel bowl o-ring leaks YM2210D #1
souperbee
Melrose/Grandin/FL.
Yanmar YM2210D
Question has anyone been having trouble with their fuel bowl leaking at the o-ring? This is my 3rd o-ring in 2 months. I don't know if it is the heat or what? I live in Florida and it has been super hot. I don't see any cracks or any imperfections on the housing. Did anyone switch over to a glass fuel bowl instead of the plastic one? Any comments would be greatly appreciated.
   / Fuel bowl o-ring leaks YM2210D #2
Are you using the correct O-ring.
Danny
I purchased the o-rings from 2 different companies. So I would think they are right.:rolleyes:
   / Fuel bowl o-ring leaks YM2210D #4
Might you be using a ethanol blend gas? Some rubber compounds don't react to well with ethanol. You might try getting a Viton or EPDM compound rubber O-Ring instead of the old Buna-N type.
If the O-Ring you have is round (the cross section that is) you might try getting a square cut O-Ring. It will have a much greater sealing surface than the round type.
(If the O-Ring you have is round (the cross section that is) you might try getting a square cut O-Ring. It will have a much greater sealing surface than the round type.)
Diesel Power, thanks for the info I will try a square ring. As far as the your other reply it uses Diesel fuel. Now I am wondering if there is a difference in orings for gas or diesel?
   / Fuel bowl o-ring leaks YM2210D #6
souperbee said:
has anyone been having trouble with their fuel bowl leaking at the o-ring? This is my 3rd o-ring in 2 months ... I purchased the o-rings from 2 different companies. So I would think they are right.
This is a long shot, but are you installing it in the right place?
The o-ring rests on that outside shoulder that is near the top of the bowl - not at the extreme top of the bowl, and not beneath the shoulder.
If that's not it, could the leak instead be from the seal for the on/off lever?
California, I believe I am installing it right, also when I purchased the tractor a little over 2 months ago. The dealer installed the first o-ring because I spotted it leaking. I replaced 2 after him. It takes maybe 2 to 2 1/2 weeks before it starts leaking after replacement. I thought vibration was the problem but the ring is tight when I check it. This thing sure has me scratching my bald head!:eek:
   / Fuel bowl o-ring leaks YM2210D #8
Fuel filter may be incorrect size. I had one that was a little longer than the original one, ended up causing a hairline crack in the clear type bowl right at the base of the lip. Part number 11 would hide this from visual inspection. With a longer filter you may not be able to torque it enough for a good seal. If the filter, o-ring, bowl are correct and both mating surfaces are smooth and clear of debris then you may just need to put a little more muscle behind the wrench.
VT_Hokie, thanks for the suggestion. I will check it out tomorrow. I want to Thank All for all the good suggestions. This is sure one knowledgeable group. Thanks All
   / Fuel bowl o-ring leaks YM2210D #10
I had this same trouble! I was told on this forum that those fuel bowls shrink over time. I ordered a new fuel bowl. I think from Hoye? Any way that is what u need. The old one was clear hard plastic and the new one is a softer cloudy plastic but it has been great for about 2 years.
8ft x 6ft Container with Side Door (A51573)
8ft x 6ft...
HARDEE D-3-816 LOT NUMBER 155 (A53084)
HARDEE D-3-816 LOT...
JOHN DEERE XUV590M LOT NUMBER 27 (A53084)
JOHN DEERE XUV590M...
2013 ISUZU NPR STAKE BODY TRUCK (A52577)
2013 ISUZU NPR...
2008 Chevrolet Suburban SUV (A51694)
2008 Chevrolet...
2020 COLOMBO TM LOT NUMBER 218 (A53084)
2020 COLOMBO TM...
