Fuel additive
/ Fuel additive #1
mopar5
SC
Kubota L3800
Does anyone use fuel additives? If so which one and how often?
/ Fuel additive #2
yup -- depends on equipment. If it my diesel tractor , white PS bottle for winter months and gray ps for summer. If it for my small gas engines, I add the marine stablizers for ethanol issues.
/ Fuel additive #3
No, but a lot of people swear by it.
/ Fuel additive #4
I do the same as Radioman. I put the PS in everything Diesel and add ethanol stabilizer in the small gas engines.
Some say it's a waste of money but I don't think so.
/ Fuel additive #5
You do NOT need to use anything. Never used any adds in my fuel, outside of MMO, for 30 years. And that is in Massachusetts.
/ Fuel additive #6
I don't use any additives for the diesels, our off road diesel is already treated for summer/winter use. I do use Seafoam for the 2 cycle tools and it does make them easier to start.
/ Fuel additive
Thanks guys for all the replies. I suppose there are pros and cons to both. Someone told me that I should to help get rid of water in fuel. Others tell me it is a waste of money
/ Fuel additive #10
Because I do not use my tractor every day my diesel can sometimes sit many weeks if not months even through seasonal weather changes. (nice fall weather working the woodlot turning into wicked cold winters when the snow blower comes out)
Here is a great article I had saved on the issue. A long read but I found it very useful.
Diesel fuel additives are simply chemicals that change the properties of untreated diesel fuel.
The biggest users of additives are refineries and distributors. Each batch of crude oil is different from the next, and each batch of refined diesel fuel is different from the next. Refineries and distributors use additives in bulk to make their diesel fuel more consistent before they sell it. This is called the “pipeline specification”.
You can see more use of additives in “premium” grade diesel. In 1999, the NCWM (National Conference on Weights and Measures) defined five properties of diesel fuel and set standards for “premium” diesel. The refiners and distributors use additives in bulk to improve the fuel so it meets one or more “premium” standard.
DO ALL BOTTLED DIESEL FUEL ADDITIVES WORK?
Most bottled diesel fuel additives work. They contain, in bottles, the same chemicals as the refinery uses in bulk to change the fuel.
I have to admit that there are less reputable brands which you should avoid. They fall in three categories:
Some less reputable brands have no active ingredients.
Some less reputable brands have alcohol as the active ingredient. Alcohol gives a short-lived boost to combustion but it wears off in a few moments, and alcohol attacks seals and gaskets.
Some less reputable brands have light engine oil as the active ingredient. Light engine oil makes an engine run smoother, but it fouls injector tips with repeated use. It also lowers energy content, horsepower, and mileage. The trucker may even get the opposite impression because he shifts gears less often. That’s because he has to run in the wrong gear in the first place.
I stress that most additive brands are reputable, they do contain chemicals that effectively improve the fuel, and do so without harmful side effects.
An additive won’t work if the trucker uses it for the wrong thing. He must understand what the additive is supposed to do. Specific problems require specific treatments. There is no magic “does-it-all” chemical. If the additive isn’t clear about what it does, or the user isn’t clear about what he wants, then the additive might not work . . for him.
IF THE REFINERS & DISTRIBUTORS USE ADDITIVES IN BULK, WHY DOES ANYBODY HAVE TO USE BOTTLED ADDITIVES?
1. You have to use bottled additives because there are additives that refiners & distributors don’t use.
The first and cheapest additive that a trucker wants is a water remover. Water enters fuel at refining, transport, storage, and engine operation. ASTM has specs for maximum amounts of water in diesel fuel. Suspended water in diesel fuel hurts combustion, lowers energy content, fouls injectors, wears out pumps, abrades injector tip needles, and causes gum and varnish. In cold weather, waters ices up and blocks fuel lines. Water can separate into oxygen and hydrogen, and combine with fuel to create sulfuric acid. You’ll never see a water remover as an additive in standard fuel or premium fuel because ppm (parts per million) of water changes daily. The only way to get a water remover is a bottled additive.
2. You have to use bottled additives because refiners & distributors don’t use enough quantity.
The refiners and distributors treat their regular grade fuels enough to make them consistent from batch to batch, or at least pretty consistent. But “consistent” doesn’t mean “good”. Impartial national organizations like ASTM (American Society for Testing and Materials), NCWM, TMC (The Maintenance Council of the American Trucking Associations) and EMA (diesel Engine Manufacturers’ Association) all have specifications for “good” fuel that go above and beyond regular grade fuel.
3..You have to use bottled additives because refiners & distributors don’t use enough kinds of additives.
I mentioned above that NCWM defined five properties of diesel fuel and set standards for calling it “premium”. The five properties are energy content, cetane number, low-temperature operability, thermal stability, and fuel-injector cleanliness.
Does a trucker get good energy content, cetane number, low-temperature operability in certain months, thermal stability, and fuel-injector cleanliness if he buys a “premium” fuel? Not necessarily. A refiner or distributor can call it “premium” fuel if the fuel meets any two of the five standards. Low-temperature operability does not apply in most months and in many locales, so a “premium” fuel assures a trucker of only one standard.
For instance, the NCWM standard for cetane in “premium” is 47. A study found one “premium” grade fuel with a cetane of only 35, which is actually below the federal minimum standard of 40 for regular grade diesel. A trucker hoping for a certain cetane number from this “premium” fuel would be badly disappointed. This situation is not rare. The most recent Premium Diesel Fuel Survey from Hart’s Diesel Fuel News shows that 26 major refiners/distributors make 34 brands of premium diesel fuel. Only one of the 34 brands of premium fuel claims to meet all five NCWM properties. Thirty-three of 34 admit to falling short on one, two, three, or four properties. Another study of 64 “premium” fuels showed none meeting all five standards.
WHAT CAN ADDITIVES DO ABOUT “GOOD ENERGY CONTENT”?
“Good energy content” translates to more miles per gallon. How does a trucker assure himself of good energy content if it doesn’t come out of the pump? The refiner can’t fix this with additives and neither can the trucker. If it’s winter, the cause might be dilution with kerosene for low temperature operability. He should find another fuel that doesn’t have kerosene, and treat it with his own bottled antigel additive. If he has to use this fuel, we only hope he’s paying less money because he’s getting less power.
WHAT CAN ADDITIVES DO ABOUT “HIGH CETANE NUMBER”?
“High cetane number” improves cold temperature starting and idling for all engines, and is required by some engines. If it doesn’t come out of the pump, there are additives that increase cetane number. TIP: the higher the cetane number of the fuel, the less effect your additive will have. For instance, we call our own product “8+ Cetane Improver” because it will boost cetane up to 8 numbers in a sub-standard fuel. But if you add it to a fuel which already has a high cetane, it will add only three numbers or even less.
WHAT CAN ADDITIVES DO ABOUT “LOW-TEMPERATURE OPERABILITY”?
“Low-temperature operability” means the fuel won’t gel up and clog the fuel lines or fuel filter. Most fuels from the pump are treated in bulk with additives or kerosene. Some meet a specification, some do not. If they don’t meet a spec, or if the weather becomes colder than the spec, or if the truck is headed to a colder area … then gelling is a risk. The trucker first wants a water removing additive, because ice forms faster than wax gels. Next there are preventative antigel additives to give more protection than the fuel from the pump. There are also remedial additives which un-gel fuel that has clogged the fuel lines or fuel filter. TIP: it’s better to prevent than to cure. Our own antigel products, “Polar Power” and “Total Power”, can be used at every fill-up without harm to any part of the system. Our own remedial product, “Melt Down”, and other remedial products, can be used only several times a season. Excessive use tends to corrode plastic and rubber parts of the fuel system.
WHAT CAN ADDITIVES DO ABOUT “THERMAL STABILITY”?
“Thermal stability” means the fuel’s ability to resist particle formation as it circulates from the tank to the engine and back again. Such particles clog filters and injectors. Truckers using high pressure injector systems with fuel as a re-circulating coolant can easily assure thermal stability with a bottled additive.
WHAT CAN ADDITIVES DO ABOUT “FUEL INJECTOR CLEANLINESS”?
“Fuel-injector cleanliness” means the fuel has a detergent that keeps clean injectors clean. Injector tips are precision instruments. Even a little dirt or varnish will damage proper spray pattern and combustion, waste fuel, rob power, and reduce mileage. Dirt is caused by thermally unstable fuel. Dirt is caused by worn needles and over-rich fuel feed; needle wear is caused by water abrasion. Varnish is caused by suspended water in the fuel. You can stop the causes of dirty and varnished injectors with regular use of water removing and thermal stabilizing additives. You can clean larger accumulations of dirt with an additive that contains a high concentration of detergent. Cummins L-10 is the accepted specification for detergency. You can keep clean injectors clean with a fuel that contains detergent.
WHAT CAN ADDITIVES DO ABOUT “LUBRICITY”?
The joint definition of “premium” grade by TMC and EMA uses the same properties as NCWM. TMC and EMA standards are a little tougher. For instance, their minimum standard for cetane is 50 compared to 47 for NCWM. TMC and EMA definition adds lubricity as another property. (In fact, lubricity was discussed by NCWM as a sixth property, but they couldn’t agree on how to measure it, and they are still working on it.)
“Lubricity” means the lubricating value of fuel. Low sulfur fuel has less lubricity. Low sulfur fuel also absorbs water more readily, and water is an abrasive. Untreated fuel often causes excessive wear on fuel pumps and injector tips. Many additives have a lubricity improver, by itself or in combination with other chemicals.
ARE BOTTLED ADDITIVES A GOOD DEAL?
Generally yes. Premium diesel is 5¢ to 15¢ per gallon higher than standard. You are assured of good quality in one to five important properties of diesel fuel. Additives cost 2¢ to 4¢ per gallon to assure good quality in one important property of diesel fuel: to remove water, to clean injectors, to lower pour point, to boost cetane three numbers, or to add lubricity. Combination additives assure good quality in several important properties of diesel fuel, and cost 5¢ to 10¢ per gallon. In most cases - but not all -- you’ll get more benefit for less money by using bottled additives.
/ Fuel additive #11
I use Opti-Lube XPD.
Here is a study that rates additives for lubricity. Opti-Lube has other diesel fuel enhancing ingredients. It seems to only be available online at Diesel Fuel Improver
Google "opti-lube review" for some eye opening evaluations from third parties.
/ Fuel additive #12
Well I just ordered some. Hope it improves things, milage and corrosion.
/ Fuel additive #13
if you never used any try a good one and you will notice a difference
prove it. My respected oil testing house will tell you most are crap. You can add engine oil and notice a difference on engine feel. That does not mean it helps at all though.
/ Fuel additive #14
Read the study listed in post #11. It has engine oil rated as well.
/ Fuel additive #15
If I understand that study, the results are based on untreated diesel fuel. The study also is missing information such as dates and source of diesel. Am I wrong?
/ Fuel additive #16
All I know is we have diesel tractors made as far back as the mid 60's, my dad had a fleet of trucks, my father in law had a fleet of trucks and was a fuel distributor, our renters have a bunch of tractors and no one has had issues and none of use additives. I have tried it and actually have some in my garage and I don't use it.
I did get good results on our BX2200 years ago, HEET and Power Service when I got some bad diesel, but when the problem was rectified I stopped. If it happens again, I will just get rid of the fuel, change filters and go from there. Of course we may all be wrong, so do what makes you comfortable. The money spent on one tractor isn't going to be a big deal.
/ Fuel additive #17
Untreated diesel fuel: Correct. Any prior additives would skew the study. A standard procedure for a scientific study is to eliminate variables or outside influence on the issue being investigated.
Source: Supply source not specifically named. Not sure that it matters since only the lubricity of the additive was being tested. The importance is that it is from the same source and batch.
"The Research firm obtained a quantity of untreated ULSD fuel from a supplier."
Date: August 2007 according to the sponsers Lubricity Additive Study Results - Diesel Place : Chevrolet and GMC Diesel Truck Forums
Also, at the very bottom of this topic is a box with links to "Similar Threads" to pursue. Seems like this topic has as variable opinions as hydraulic oil or engine oil. :p
/ Fuel additive #18
While I admit it's not necessary to add anything during the summer, but winter months, I DEPEND on my BX for a variety of tasks. I don't NOT want to deal with gelled fuel. I have no home test I can do other then take a small sample and put in the freezer for couple days before I fill up the tank. I am not sure if my wife is keen on having a sealed bottle of diesel in the freezer with the food I have in there.
The white bottle PS is the biggest stress reliever in my mind when adding it to diesel during the summer. For all I know I can blame Power Service and try to take them to court if my fuel EVER gells up. :laughing: .
So where does this leave us? Do you HAVE to use additives? a simple NO will suffice. Its how you want to be protected. No one is holding a gun to your head to use it, but when if gels up ..... or if the engine shows abnormal wear from low lubricity of the ultra low sulfur diesel ..... :confused3: . I don't know the clear answer to this. I just know I am not familiar with teardown and rebuild of diesel engine as I never done it nor I haven't had the pleasure of gelled fuel, changing TWO filters on the BX and adding 911 to get going again yet. I don't care about adding more cetane's since my tractor is not over 25 hp.
I am calling the additives cheap insurance in my mind. :eek: Call it what you will and want to do.
/ Fuel additive #19
I agree but you can play the cheap insurance game all day; even with engine oils too! LOL.
In my 30 yearss with diesel, no adds other then MMO and at -21 F a few years ago, no issues in MA winters.
If you use an add I would get UOA's since again results can be crap using them. Good luck! If not, you will be fine with winter fuel. YMMV
/ Fuel additive
Wow! This is a lot of info to go through. I guess when it comes down to it, do you trust the supplier put in additive. I know that with my job in the propane business, if we dont add methanol to the tanks it will cause the regulator to freeze up. We do have a few slackers that forget to do it. I guess if one wants to be safe, a little additive wouldnt hurt would it?
Case IH Onland 3pt 6 Bottom Flip Plow (A64119)
Case IH Onland 3pt...
2008 Toro Multi Pro 1200 Turf Sprayer (A61572)
2008 Toro Multi...
2026 Stout TB-76 Tri-Blade Brush Cutter (A64047)
2026 Stout TB-76...
2019 MERTZ MANUFACTURING MANIFOLD TRAILER (A58216)
2019 MERTZ...
2026 DEVELON DX27Z-7 EXCAVATOR (A64279)
2026 DEVELON...
KUBOTA SVL97-2 SKID STEER (A64279)
KUBOTA SVL97-2...
