FT Foton 404 PTO Problem
   / FT Foton 404 PTO Problem #1
Walter L
Delhi LA
LS XG3135, Foton FT404,Farmtrac 555 ,Kubota L245H offset garden tractor Mahindra 2660 cab tractor
The PTO is stuck in the low speed position and the shift leaver will not move on my Foton 404, I have had the tractor going on 7 yrs trouble free and would appreciate any advice on where to start on correcting the problem.
Walt
   / FT Foton 404 PTO Problem #2
Thanks Tommy no it not froze from not using its something inside im just not sure where to start, from my parts book that came with the tractor it looks like I should start with the top plate in the rear of the tractor above the PTO shaft? The lever that shifts between hi speed neutral and low speed is springy feeling. The tractor has about 190+ hrs on it.
Walt
Then I will start with removing the lift box, Unless some one has any thing to add. Thanks
Walt
   / FT Foton 404 PTO Problem #6
Yeh, I agree, if it's like my 254 foton, than the oil box under the seat must come off to access the rear end, disconnect the tubes to the box, take the seat off and remove the bolts all the way around. you'll need new gasket seal before putting back on. My pto lever is on my left side when driving so it's switching a gear inside I believe.
Diesel Fuel Tank with Pump (A50860)
Diesel Fuel Tank...
2008 Ford Crown Victoria Sedan (A48082)
2008 Ford Crown...
UNUSED White Metal Roof Panels (A50860)
UNUSED White Metal...
2007 INTERNATIONAL 7400 DT466 SFA 4X4X CHASSIS TRK (A51406)
2007 INTERNATIONAL...
2019 Allmand Light tower (A49461)
2019 Allmand Light...
2015 Ford F-250 4x4 Liftgate Service Truck (A48081)
2015 Ford F-250...
