FS: Westendorf Brush Crusher 4215 Grapple - SOLD
Item Details
Type
Year
2022
Condition
Used
Price
1000
Model
4215
Item status
  1. Sold
Marketplace Terms & Conditions
  1. I have read and agree to the rules and terms of use
DSCF1142.JPG4215x.jpegDSCF1279.JPGDSCF1278.JPGDSCF1277.JPGDSCF1276.JPGThe Westendorf Brush Crusher attachment is used for clearing trees, handling brush, or even cleaning up trees and debris after a storm. The Brush Crusher Model 4215 is a mid-sized model of the Brush Crusher line-up, and is adjustable so you can get the tooth action that you need (wider or narrower). It is designed to fit on loaders with a JD style coupler. This is a mechanical grapple that does not require hydraulics to use. I have used it for the last couple of years, it has a couple of slightly bent tines, works as it should. $1,000.
   / FS: Westendorf Brush Crusher 4215 Grapple - SOLD
The Westendorf Brush Crusher attachment is used for clearing trees, handling brush, or even cleaning up trees and debris after a storm. The Brush Crusher Model 4215 is a mid-sized model of the Brush Crusher line-up, and is adjustable so you can get the tooth action that you need (wider or narrower). It is designed to fit on loaders with a JD style coupler. This is a mechanical grapple that does not require hydraulics to use. I have used it for the last couple of years, it has a couple of slightly bent tines, works as it should.4215x.jpegDSCF1279.JPGDSCF1278.JPGDSCF1277.JPGDSCF1276.JPGDSCF1142.JPG
2000 Kenworth T800 Roll Off Truck (A53117)
2000 Kenworth T800...
Yanmar YM226 2wd tractor (A53473)
Yanmar YM226 2wd...
LATE MODEL JOHN DEERE EQUIPMENT AUCTION (A53084)
LATE MODEL JOHN...
2008 Volkswagen Passat Sedan (A51694)
2008 Volkswagen...
2018 Toro Workman GTX Electric Utility Cart (A54811)
2018 Toro Workman...
2020 GENIE TZ-34/20 TOWABLE MANLIFT (A51242)
2020 GENIE...
