frost free Hydrant problems
   / frost free Hydrant problems #11
This sounds like a water supply problem, not a hydrant problem.
   / frost free Hydrant problems #12
My neighbor called one cold morning to say she had no water to her house. Her husband was deployed. :(
I told her to take the hair dryer and put some heat to the tiny pipe on the grey thingy in her well house until she heard a click. :)
She called back less than 10 minutes later to say she had water. :)
   / frost free Hydrant problems #13
Are you pretty sure that they are still frozen, or is there a chance that the operating rod or valve plug down below the surface is broken? The entire top head of the hydrant can be unscrewed from the riser pipe to check and repair or replace these parts as needed. BUT don't do this unless you have a means to cut off the water supply source somewhere or you may wind up with a gusher in the barn! You will likely need a large pipe wrench on the riser pipe and either another large pipe wrench or adjustable wrench for the head. Good luck, and WELCOME to the forum! :welcome:
- Jay
Before taking the head off the standpipe; lift the handle to the full open position.
2012 MACK GU (GRANITE) CAB & CHASSIS (A56129)
2012 MACK GU...
Forklift Safety Basket (A56857)
Forklift Safety...
Year: 2019 Make: Nissan Model: NV200 Vehicle Type: Van Mileage: 88,557 Plate: Body Type: 4 Door Van (A55853)
Year: 2019 Make...
1998 INTERNATIONAL 9100 WATER TRUCK (INOPERABLE) (A55745)
1998 INTERNATIONAL...
Willmar 4550 Wrangler Articulating Loader (A56435)
Willmar 4550...
2025 ZWB 59in Excavator Boom Mini Skid Steer Attachment (A56857)
2025 ZWB 59in...
