Price Check Frontier SB1164 Snowblower
   / Frontier SB1164 Snowblower #12
Thanks for all the feedback
Wayne - I have the front mount blade that Kenny custom mounted for me earlier this year it totally rocks!!! I do not have or will use chains as they will tear up the asphalt driveways.
I also had a 29 inch NOMA walk behind blower which was nice but I do enjoy the snow blade way more.
I appreciate the heads up on the windows and such from Don -- one plus I can think of though is that I should be able to knock off most of the snow on the evergreen trees near my driveway which may avoid them breaking apart from the heavy snow load.
Thanks to Dave for sharing your SB1174 experience too, I'm sure his advice will bear out for me too.
A special thanks to JDGG for the picture of the blower, I can't wait
I use chains on my asphalt driveway and it doesn't tear it up. I am careful to minimize spin. But, if it spins, only very light scratches are left behind. Nothing I would characterize as damage. The scratches aren't even noticable unless you just sealed your driveway. Of course, my little JD425 isn't as heavy as a CUT/SCUT.
   / Frontier SB1164 Snowblower #13
I just watched your video. While it's hard to really tell from the video, it looks like you aren't keeping your blade angled as sharp as possible at all times. When the snow is as deep and heavy as our last fall, it's tough to go at it like a bulldozer, pushing strait ahead. It's much more effective to go at like a herring bone pattern making two side by side passes that overlap significantly in the middle. Push one side and then the other until you get a clear path to the street. This helps keep the snow from building up in front of the blade. Then you can take bites that leave the leading edge of the blade clear, and she'll push much better.
You also have enough ground clearance to just take half of it at a time until you get that first pass clear, if you have to. That's what I do when plowing the neighbor's driveway up a steep hill until I get to the top. Then I can push it down hill from there. Sometimes I do have to backdrag, on his driveway, though, because I have very little ground clearance with AWS.
   / Frontier SB1164 Snowblower #14
Hi Joe,
I just bought a RADTech Blizzard B64. They supply Frontier with their blowers. Perhaps you have a dealer nearby ?
RAD Tech-Souffleuses à neige
I did not opt for the hydraulic turn. For me, the ergonomics of the rotator handle are more comfortable than trying to access the rear remote lever when you are turned around.
My test was backing into my lawn and blowing 15" of packed wet snow. It did very well on the back of my 3320.
John
Thanks Kyle I plan to put up a much better video later; I was just anxious to put a video out to share for now. I did one this while holding the camera in my right hand while trying to operate the blade movement and steering with my left hand.
I know that I could have really improved how I handled the angling of the plow (as Gittyup notes), but again since I was one handed it did not do well this time. I did try to angle as much as I possible on the right side and veer the tractor right too. As I get more seat time and a mount for the camera I should get much better at this.
I could not find any local RADTech dealers near me, but it does look awesome on the link and I知 sure it would be great on the 3320. Just curious what you were able to get it for ($).
   / Frontier SB1164 Snowblower #16
Yea, the chains do not damage the asphalt, worst case is some light scuffing, but I can push!
Wayne
   / Frontier SB1164 Snowblower #17
Forgot to consider that you were holding a camera at the same time. Keep on plowing:thumbsup:.
2011 GROVE TMS900E TRUCK CRANE (A58214)
2011 GROVE TMS900E...
2017 Jacobsen Greens King IV Plus Reel Commercial Mower (A56857)
2017 Jacobsen...
JOHN DEERE 9570 RX (A58214)
JOHN DEERE 9570 RX...
JOHN DEERE 410L BACKHOE (A52706)
JOHN DEERE 410L...
2023 yamaha (A55758)
2001 Ford Crown Victoria Passenger Car, VIN # 2FAFP71W41X143155 (A57453)
2001 Ford Crown...
