Frontier RB2060L Owners
   / Frontier RB2060L Owners #1
Timberman444
Northwest, CT
John Deere 2320
I thinking about buying the 5' rear blade and have a few questions about it, whats the total height moldboard+cutting edge, and when the blade is angled all the way (either side) how wide is the width of the cut?
   / Frontier RB2060L Owners #2
One work on the RB2060L, DONT. It is a piece of crap. In one season I had bent that toy blade enough that I needed to back up to a tree and strike the outboard ends so that I wasn't pulling a V-plow through the snow.
-The curvature of the moldboard was almost eliminated in one heavy winter
-The pivot pin has no nylon lock-nut or bearing style castle nut, so it is constantly working itself loose with regular use
-The angle establishment is wheenie and loads applied easily bend the cheesy pin
For your money your way better off going with a Land Pride RB15.
   / Frontier RB2060L Owners #3
can you please let us know what you were pulling with as to determine if the blade in question was destroyed due to poor engineering or maybe outmatched. the L designator is specifically for subcut's with limited lift height which are generally not powerful enough to tear them up.
   / Frontier RB2060L Owners #4
A 2305 JD was all that pulled it.
   / Frontier RB2060L Owners #5
Chad, not to be critical of you...................but maybe you should take it a little easier on your equipment. Bent loader mounts and bent rear blade. Something tells me you are asking too much of your tractor and attachments.
Sincerely, Dirt
   / Frontier RB2060L Owners #6
Sincerely, Dirt
I was thinking the exact same thing.
   / Frontier RB2060L Owners #7
I have been using the RB2060L on my 2520. I use it for snow removal and dirt/gravel. I don't have the measurements, but I do wish I would have gone with a bigger blade. No problems with anything bending or breaking at all, but just to have the extra reach. It was just such a better deal (dealer had in stock trying to sell) than ordering a bigger one. So from that perspective I'm satisfied as it does exactly what I need it to do.
UNUSED DIGGIT HEAVY DUTY 20'X20' ALL-STEEL CARPORT (A54757)
UNUSED DIGGIT...
2011 DOOSAN G40 GENERATOR (A53843)
2011 DOOSAN G40...
SCAN FOR HAULING AND FINANCING INFORMATION (A52705)
SCAN FOR HAULING...
KUBOTA SVL97-2 SKID STEER (A52705)
KUBOTA SVL97-2...
2015 Ford Focus (A51694)
2015 Ford Focus...
2017 Ford Fusion Hybrid Sedan (A55758)
2017 Ford Fusion...
