Frontier Middle Buster bolt spacing question
   / Frontier Middle Buster bolt spacing question #1
Rmd8136
Ft mill, sc
Deere 5065e MFWD
I have the PM1001 middle buster. The mould board has 3 bolt hole to attach to plowstock. The center one is not used. The top and bottom holes are 7/16" carriage bolt square holes , 2 1/4" ctr spacing. The two holes in plowstock foot are 1/2" diameter at 2" ctr spacing. The bolts are common grade so they would break before damaging plow if you snagged something hard. I tried putting in 7/16" bolts so they would not break easily in hard ground. Since the spacing on mould board is 2 1/4" vs the 2" spacing on plowstock foot, the bolts are not parallel. You can only hit both front and back holes with the skinnier 3/8" bolts. I have asked dealer about spacing discrepancy and they can't produce a drawing showing intended spacing. They ordered a new one to measure and compare to mine, assuming new one is made correctly. The original bolts were 3/8" low grade carriage bolts which will fit through both holes even though not parallel. I am currently using a Gr 5 stronger hex bolt with washer on front side (leading face) but it is not a carriage bolt. It is holding up fine in the stiffer soil I am using it in. I was using the buster to break up some ground before discing since I don't have a 1 or 2 bottom plow yet. Probably misusing it but I have it and was using it to lay out some rows for corn after breaking up ground. Has anyone noticed this bolt spacing discrepancy? I can't imagine it is intentional to have non-parallel bolts. I got the middle buster as a 2nd inexpensive implement to get 1500 rebate. Kinda neat and versatile implement. I am looking for 2 bottom plow for breaking up ground. Thanks for any help with this curiosity.
2005 Dodge Caravan Van (A54815)
2005 Dodge Caravan...
2010 Ford Transit Connect Cargo Van (A53117)
2010 Ford Transit...
UNUSED Woven Landscape Fabric (A53117)
UNUSED Woven...
20 ft. Shipping Container (A53117)
20 ft. Shipping...
2021 JOHN DEERE HX14 (A53084)
2021 JOHN DEERE...
SET OF (4) ALCOA 24.5 ALUMINUM RIMS (A53843)
SET OF (4) ALCOA...
