Frontend noise
/ Frontend noise #1
Straphanger
Kubota BX 2670
My BX 2670 has a clicking noise in the left front wheel sometimes. Think it could be a wheel bearing?
/ Frontend noise #2
Could be. Could be a lot of other things too. Not much information to try to help.
Have you lifted the front end up and hand spun it? Happen with 4WD engaged and not? Does it happen when turning the wheels? Etc
/ Frontend noise
It does it in 2 or 4 wheel drive. I did jack it up and spin the wheels--no noise. When I drive it I can hear it, mostly when turning.
/ Frontend noise #4
Have you checked the lugs for tightness? May be some slop which shows up mainly while turning. Not sure what the hub assembly is like but might needs some snugging up there?
/ Frontend noise
The lugs are tight. I even took off the wheel to make sure there was nothing jammed in there.
  • Good Post
Reactions: JWR
/ Frontend noise #6
Front u-joint going bad makes a clicking noise but I would always say it's on the right front. Easy to change.
/ Frontend noise
It sounds like a u-joint but is on the left front. I think I'll pull the shaft and check it. Does it come out easy?
/ Frontend noise #8
Just pull the boot (cover) to check. If you need it off jack the front of the tractor let the axle pivot down on the shaft side. Then 2 pins (may be doubled roll pins that need some force) after that there should be enough room to remove the joint. Used be $50 or so part from Kubota.
/ Frontend noise #9
Also make sure the axle is not low/out of oil, the tend to leak a bit with age.
/ Frontend noise #10
Occasional clicking is not a reason to start pulling u-joints apart! I'd give this a lot more time and watching before doing anything rash.
/ Frontend noise #11
U joints on the BX do not come apart, just like steering knuckles. Sealed bearing that are not replaceable when they go bad. Pulling the boot and checking takes seconds....
ROANOKE S/A LOOSE LEAF TRAILER (A63291)
ROANOKE S/A LOOSE...
2019 HYUNDAI V12530152-AJS DRY VAN (A59912)
2019 HYUNDAI...
JOHN DEERE 5403 TRACTOR (A58375)
JOHN DEERE 5403...
(4) Tex Star 205/75D/15 Tires and Rims (A64047)
(4) Tex Star...
2018 FREIGHTLINER M2 4X2 S/A 26FT NON CDL BOX TRUCK (A59911)
2018 FREIGHTLINER...
John Deere 4230 Tractor w/ Loader Bucket and Hay Spear (A64047)
John Deere 4230...
