Front wheels locked up on my 3120r
   / Front wheels locked up on my 3120r #1
Coachjames
Branson 3120r
So as the topic says the front wheels locked up and won't turn in 2 or 4 wheel drive. If you lift the tractor up with the loader and get the wheels free they will spin freely but in opposite directions. Anyone with any thoughts as to what it might be?
   / Front wheels locked up on my 3120r #2
And if you moves both wheels in same direction it is locked?
yup both lock if I try to go in the same direction
   / Front wheels locked up on my 3120r #4
Sounds like front differential gear problem to me.
   / Front wheels locked up on my 3120r #5
On my 2400H the input shaft bearings went out and caused the wheels to randomly lock.
On the 2400 this shaft goes inside of a sheet metal cover tube so you has to remove this cover to find the problem.
   / Front wheels locked up on my 3120r #6
As the second owner of a low-time 2400H (only 70 hours), do you mind telling me how much time you had when those bearings died? Was it just time for them to go or was the front axle low on fluid or what? Since I'm a tractor newb, I figured I should learn as much as I can from the experience of others! Thanks, and sorry, OP, for the thread drift!
TXCOMT
   / Front wheels locked up on my 3120r #7
It could be a ring and pinion or input shaft bearing issue, it is also a possibility that it is in the tractor output to the front drive.
The only way to be sure is to remove the driveshaft to the front end if the front end is still locked up with the driveshaft removed it is in the front axle,
if it is back to normal it is in the tractor drive end.
Good Luck.
   / Front wheels locked up on my 3120r #8
TXCOMT
I believe it was less than 50 hrs on the clock & not low on oil either. Dealer & I both suspected faulty assembly from the factory. Complete new axle was installed and around 530 hrs on machine now with no problems.
Generac Generator (A51691)
Generac Generator...
Year: 2012 Make: Nissan Model: Maxima Vehicle Type: Passenger Car Mileage: 134,973 Plate: Body Ty... (A51694)
Year: 2012 Make...
JOHN DEERE Z920M LOT NUMBER 238 (A53084)
JOHN DEERE Z920M...
36in Excavator Bucket (A51573)
36in Excavator...
HARDEE RD72M LOT NUMBER 158 (A53084)
HARDEE RD72M LOT...
2009 Freightliner M2 106 MedTec Ambulance (A51692)
2009 Freightliner...
