front wheel seals
/ front wheel seals #1
azranger
az
LS G3033
I don't know if anyone else has had this problem, my 3033 started leaking oil from the front wheel seals , only 104 hrs on it. taking it back to dealer next week.
/ front wheel seals #2
No leaks on my XR3037HC but only have 70 hours on the clock. Maybe some 3033 owners while chime in.
Is it possible the front axle was over filled during the 50 hour service. Mine was low when I checked it. I topped it off but didn't overfill. Still lots of snow here so I'd know if I had a leak.
/ front wheel seals
When I pull the stick on it, it is in the middle of the safe zone. It only leaks enough to mess up the inside of the wheel. The dealer said they had not had any issues that they knew of, but they would replace them. Thank goodness for warranty.
/ front wheel seals #4
Warranties are a good thing especially with the costs of tractor parts. It's just the hassle of taking it in, leaving it, then picking it back up. Not to mention being without the tractor for the duration of the repair.
Glad their going to take care of it.
/ front wheel seals #5
The G3033 has a dip stick on the front axle?
/ front wheel seals #7
Mine has one on the left side
So does my XR3032H. It looks just like a regular cap from an oil bottle. Once you unscrew it, you'll see the dipstick.
/ front wheel seals #8
Many differences between models. Mine just has a pipe plug you take out. If it runs out the hole you're good.:laughing:
/ front wheel seals #9
While we're on the subject, there are 2 more plugs out by the wheel. I know the bottom one is a drain but I took the top one out and the oil level was down about 2" , it was the same on both sides. The plug on the right of the pic (towards the center of axle) was full. It appears the plugs out by the wheel are at a higher level than the one towards the center of axle.
Question is;
Is that all the same as the axle or should the plugs by the wheel be filled up to the plug?
I'm having a hard time explaining this, I hope the pics show what I'm trying to ask! :)
/ front wheel seals
<img src="http://www.tractorbynet.com/forums/attachment.php?attachmentid=416959"/><img src="http://www.tractorbynet.com/forums/attachment.php?attachmentid=416960"/>
Question is;
My axle is made a little different than yours but the oil level where I check mine at is down about 2 inches as well.
/ front wheel seals #11
Mine looks like a pipe plug too. Take a wrench, remove it, and then you'll find the dipstick attacked to the underside of the pipe plug. I was surprised at that too.
/ front wheel seals
I called the dealer today to see what he found out about my tractor, he said that he really doesn't know what caused the seals to leak especially on both axles at the same time. He said that when he pulled the axles that there was a little play , but did not think it was enough to cause them to leak. So he went ahead and ordered new bearings as well as seals, should be ready next week.
/ front wheel seals #13
the oil is all shared in the front axle the top outer plug is for air release when filling the center plug on main housing is the proper fill level
/ front wheel seals #14
Thanks, that was the answer I needed! :thumbsup:
2015 Nissan Frontier Ext. Cab Pickup Truck (A64556)
2015 Nissan...
2022 EZ-GO ELITE...
2016 New Holland Boomer 47 4WD 45HP Loader Utility Tractor with Bush Hog BH16-2 Brush Cutter (A64553)
2016 New Holland...
2001 FREIGHTLINER FLD120 T/A 6X4 DAY CAB (A67147)
2001 FREIGHTLINER...
2021 Redirective Crash Cushion Guardrail (A64556)
2021 Redirective...
2013 Ford F-550 Altec AT37G 37ft Bucket Truck (A61573)
2013 Ford F-550...
