Front wheel REVERSE
/ Front wheel REVERSE #1
1Dangerous1
Monroe, Virginia
Yanmar 1300d, cub cadet 1200
I have just finished going through a recently purchased Yanmar 1300d, and was wondering if anyone had revered the front wheels on there's? I have done this to get a wider stance, but it kind of feels like the steering changed, so I was wondering if the wider track would cause stress to the gears in 4 wheel drive? Thanks in advance for the help.
/ Front wheel REVERSE #2
You've got a little bit of a can of worms here...but not too much.
Steering: You've changed the steering axis. In a sense, you've changed the relation to how far away the pivot is in relation to the outside of the tire. Think of it as a simple lever. The farther away from the pivot, the harder it will be to move. It'll cause a bit more strain on the steering components such as tie rods, gearbox, and your arms.....but it's nothing that should cause any damage. (unless you're worried about looking like popeye)
4 wheel drive:
This comes back to the general rule of "don't use it on hard surfaces". The front and rear wheels take a different track when you turn. So a bit of a "softer" surface is needed to allow for some slip between the front and rear end. If you widen the rear track, it becomes less of an issue, but just make sure that you keep it out of 4WD when you don't need it. That's the simplest solution.
Hopefully this all helps.
/ Front wheel REVERSE #3
I widened the wheels on my 4220D and other than a bit harder to steer, I had no problems. I cant see that it makes any difference on the bearings or gears as it just transfers the force from the outer bearing to the inner bearing as the fulcrum is still at the same spot, you just swapping side with the lever (lever being the dish in the tire rim). I may have gotten some wear in the tie rod ends after 4 years of running but not enough to be a problem. I also widened the rear tires to match. I did this soon after I bought it because of the hills we have here so I had more stability. I have no doubt that at least once that saved me from turning over.
Thanks for the reply I had already moved the rear out also. I just do not want to bust a gear, so it sounds like I will be ok.
Thank you for the great information I was hoping that was the case.
/ Front wheel REVERSE #6
No, I don't believe it makes a difference.
But I went another route and it really does make a difference.
/ Front wheel REVERSE #7
That is a beautiful resto!
JMR mini trailer mover attachment (A61567)
JMR mini trailer...
2018 Ford Explorer AWD SUV (A61574)
2018 Ford Explorer...
2015 Peterbilt 367 T/A Wet Kit Sleeper Cab Truck Tractor (A56858)
2015 Peterbilt 367...
2014 International WorkStar 7300 4x4 Altec A55F 55ft. Material Handling Bucket Truck (A60460)
2014 International...
CASE 105C (A62177)
CASE 105C (A62177)
GOLF CART (A63569)
GOLF CART (A63569)
