Nov 22, 2021 / Front wheel oil leak #1 G Greentrac New member Joined Nov 22, 2021 Messages 1 Tractor Deutz-fahr Pls help how to repair front wheel leaking oil
Nov 22, 2021 / Front wheel oil leak #2 M mcfarmall Veteran Member Joined Oct 1, 2015 Messages 1,482 Location Kalamazoo, MI Tractor Kubota M5660, Farmall C, JD 260 lawn tractor Vehicle make and model will elicit more helpful responses.
Nov 22, 2021 / Front wheel oil leak #3 E ericm979 Super Member Joined Nov 25, 2016 Messages 5,930 Location Southern Oregon Tractor Branson 3725H Deere 5105 Most likely one or more seals have failed. They can fail on their own or because the bearings are going bad and the play has damaged the seals.
Nov 22, 2021 / Front wheel oil leak #4 Roadworthy Elite Member Joined Aug 24, 2019 Messages 4,055 Location Southeast Washington Tractor Kubota L2501 HST, Try to identify the source of the oil leak. Make sure it's not dripping down from somewhere else. Since you say oil not grease you probably have a four wheel drive tractor. They do have a kind of gearbox near each front wheel.
Nov 22, 2021 / Front wheel oil leak #5 ljjhouser Veteran Member Joined Oct 25, 2018 Messages 1,387 Location Midwest - Ozarks Tractor Kubota L4701 Welcome to TBN. Location. More information is usually required, even pictures.
