Front wheel lug bolt size TC40DA?
   / Front wheel lug bolt size TC40DA? #1
lhfarm
Central Indiana
NH TC40DA
We finally had enough rain so I could disc a small area around the outside of my field I need to burn next spring. After making a couple of passes, I pulled into the barn, hopped off the tractor and saw that left front was flat and the bead broken. My compressor is in the garage and I didn't want to drive on the tire. Thought I'd remove the wheel, but not sure of the socket size. A 7/8" doesn't seem tight enough. I don't have a metric socket that large to try. I've been searching the owners manual and see the torque specs, but not size.
I have a portable compressor, so after searching here, think I'll haul it down to the barn and try removing the valve core and using some soap and straps. If I have to remove it, I think it is going to take an impact wrench.
Any other tricks/advice - other than to check the pressure more than once every 2 years :(
   / Front wheel lug bolt size TC40DA? #2
7/8" it is. Metric wheel hardware and pilot & lug circle metric dimensions disappeared when the TC's arrived. I avoid using 12 point sockets on wheel hardware. In fact, I pretty much avoid using 12 point sockets altogether.
Thanks, I'll pick up a five point tomorrow. Hoping it was just low.
   / Front wheel lug bolt size TC40DA? #4
"Thanks, I'll pick up a five point tomorrow."
Six point is more commonly available and will fit your lug bolts. :D :D :D
OK, tried the portable compressor and a strap around the tire. No progress. I used my SIX point 7/8" socket and impact wrench and now have the tire on the floor. I can't figure out the valve, so I may just take it in to a tire place this week.
The real BAD news is that the left REAR was down. I aired it up, but I am now wondering if I hit something on that side. If the rear is down when I return next weekend, I'll have to get a service to come out.
   / Front wheel lug bolt size TC40DA? #6
Sounds liek you may have done in both tires on that side. I have had similar experiences over the years.
Andy
New Swict 60" Skidloader Bucket (A50774)
New Swict 60"...
2014 Gillig G27B102N4 31+56 Low Floor Passenger Bus (A50323)
2014 Gillig...
2018 CATERPILLAR 305E2 CR EXCAVATOR (A51242)
2018 CATERPILLAR...
2014 CATERPILLAR CB54 XW SMOOTH DBL DRUM ROLLER (A51242)
2014 CATERPILLAR...
71067 (A49346)
71067 (A49346)
Friesen 220 Seed Tender (A50514)
Friesen 220 Seed...
