Front wheel lug bolt size TC40DA?
   / Front wheel lug bolt size TC40DA? #1
lhfarm
Veteran Member
Central Indiana
NH TC40DA
We finally had enough rain so I could disc a small area around the outside of my field I need to burn next spring. After making a couple of passes, I pulled into the barn, hopped off the tractor and saw that left front was flat and the bead broken. My compressor is in the garage and I didn't want to drive on the tire. Thought I'd remove the wheel, but not sure of the socket size. A 7/8" doesn't seem tight enough. I don't have a metric socket that large to try. I've been searching the owners manual and see the torque specs, but not size.
I have a portable compressor, so after searching here, think I'll haul it down to the barn and try removing the valve core and using some soap and straps. If I have to remove it, I think it is going to take an impact wrench.
Any other tricks/advice - other than to check the pressure more than once every 2 years :(
   / Front wheel lug bolt size TC40DA? #2
7/8" it is. Metric wheel hardware and pilot & lug circle metric dimensions disappeared when the TC's arrived. I avoid using 12 point sockets on wheel hardware. In fact, I pretty much avoid using 12 point sockets altogether.
Thanks, I'll pick up a five point tomorrow. Hoping it was just low.
   / Front wheel lug bolt size TC40DA? #4
"Thanks, I'll pick up a five point tomorrow."
Six point is more commonly available and will fit your lug bolts. :D :D :D
OK, tried the portable compressor and a strap around the tire. No progress. I used my SIX point 7/8" socket and impact wrench and now have the tire on the floor. I can't figure out the valve, so I may just take it in to a tire place this week.
The real BAD news is that the left REAR was down. I aired it up, but I am now wondering if I hit something on that side. If the rear is down when I return next weekend, I'll have to get a service to come out.
   / Front wheel lug bolt size TC40DA? #6
Sounds liek you may have done in both tires on that side. I have had similar experiences over the years.
Andy
2025 12V Diesel Pump and Hose (A50324)
2025 12V Diesel...
2019 CATERPILLAR 308 CR EXCAVATOR (A51242)
2019 CATERPILLAR...
2024 CATERPILLAR 299D3 XE SKID STEER (A51242)
2024 CATERPILLAR...
PREVIEW DATES AND TIMES (A51572)
PREVIEW DATES AND...
2019 Chevrolet Silverado 1500 4x4 Crew Cab Pickup Truck (A50323)
2019 Chevrolet...
2021 FORD F450 TOW TRUCK (A50505)
2021 FORD F450 TOW...
