Front Wheel Drive Not Working
/ Front Wheel Drive Not Working #1
Bobby boy
Butternut
Bobcat CT22
Had seen a couples post from a few years ago that owners had problems with front wheel drive not working and a few suggestions on checking couplings and splines on drive shaft. We have now the same problem with ours after moving 16 yards of pit run and 16 yards of sand gravel mix that was really wet. Have tractor lifted up coupling and splines ok front wheels turn opposite of each other and it doesn't seem to be a gear problem but holding back the driveshaft you can turn the wheels. So before we start tearing apart the front differential wanted to know if others had this problem and what they found was the cause.
Thanks in advance for any help.
/ Front Wheel Drive Not Working #2
Haven't had the problem but do have a thought on it. If one wheel turns the other the opposite direction that indicates differential and wheel gears are working. If in turn you can hold the drive shaft that would indicate to me a broken pinion shaft or sheared pinion teeth.
This is only if you can turn the wheels the same direction while holding the shaft. If you were to hold the shaft the wheels would normally turn in opposite directions. Make sense?
Good test for the front would be to see if you can turn the differential pinion with the wheels on the ground and shifter out of gear. If so, a problem somewhere in the front end.
Thanks will try that too, hate to take apart if its not that area. Starting after breakfast and hope to find problem area sure miss not having tractor.
/ Front Wheel Drive Not Working #4
Curiosity killed the cat but hasn't got me yet, where is Butternut? And welcome to the forum. :welcome:
Bunch of wisdom lurks this forum.
Far northern Wisconsin which we call Gods country. About 60 miles south of Ashland WI.
/ Front Wheel Drive Not Working #6
Brrr! But then you don't have the hooooot summer days like we do the in Heaven of Texas. :D
Ok problem found, to me its the weak point in front diff case. Part is cast diff case cover part 6695052. 1501192308280589732623.jpg1501192308280589732623.jpg
Thanks have that part seal and o rings on order should be here next week, will keep that part number on hand just in case this happens again.
40' Used Container, High Cube, Single End Doors (A62679)
40' Used...
2014 Dodge Journey SUV (A61574)
2014 Dodge Journey...
2016 Chevrolet Silverado 1500 Pickup Truck (A64194)
2016 Chevrolet...
2006 Ford F-350 4x4 Crew Cab Pickup Truck (A61573)
2006 Ford F-350...
2015 Hyundai VC2530152 53ft. T/A Dry Van Trailer (A61573)
2015 Hyundai...
2005 BOBCAT 323J EXCAVATOR (A64279)
2005 BOBCAT 323J...
