Front wheel bent?
   / Front wheel bent? #1
jorswift
Upland, IN
JD955, MF1528, JD2240, JD 4300, Ford Jubilee
Ok excuse my ignorance, but I know most tractors with a FEL have some toe in with the front wheels to offset weight or heavy loads. However, looking at my front end, it looks like the left hand side(drivers side) is leaning way more than the right. Is this normal? How does one go about fixing or aligning it better?
   / Front wheel bent? #2
If it's MFWD, there is no adjustment and HIGHLY unlikely something is bent. It appears perhaps your front axle is pivoting a little as the ground isnt level and that gives the impression one side has more toe in.
   / Front wheel bent? #3
What CKF said.
   / Front wheel bent?
Thank you. Yes it is a MFWD
   / Front wheel bent? #5
I agree. You can even see how tilted the front axle is compared to the loader cross member.
Check in a flat surface. Also check tire pressures on all 4 tires.
   / Front wheel bent?
Here is a pic of tires aired to spec and on level ground.
   / Front wheel bent? #8
Good Evening jorswift,
Looks good on a level and flat surface !!
Looks like CKF fixed your problem !!
2025 Full Body Zero Gravity Massage Recliner Chair (new/Unused) with High Fidelity Bluetooth Surr... (A59225)
2025 Full Body...
New/Unused Quick Attach Pallet Forks (A57454)
New/Unused Quick...
2008 Ford F650 XL Landscape Dump (A55272)
2008 Ford F650 XL...
WHISPEREATT 25 GENERATOR (INOPERABLE) (A58214)
WHISPEREATT 25...
CHAIN LINK CHICKEN PEN (A58374)
CHAIN LINK CHICKEN...
1993 Ford F-250 (A56858)
1993 Ford F-250...
