Front wheel bearings and cv joints
   / Front wheel bearings and cv joints #1
jaw773
Toolcat 5600
I understand that on a toolcat 5600 independent front axle unit that 04-07 Colorado bearings work on this machine. My question is 2wd or 4wd and the listing are left and right, I would guess it's regarding abs for the truck??
Also anywhere cheaper to get cv axles for this machine??
Thank you in advance
   / Front wheel bearings and cv joints #4
The 4wd unit is the correct one because it has the splined center section to accommodate the cv axle shaft.
If your getting a unit listed for the GM or Isuzu vehicle it doesn't matter if you get left or right because when you remove the ABS harness there is no longer a difference between left and right. It is also possible to buy hubs that do not have ABS sensor/harness, below are some part numbers that my research indicated should be a match.
BR930703 (SKF)
051-6367 (Beck/Arnley)
HA590304 (Timken)
715110 (Raybestos Brakes)
515121 (MOOG)
The only difficult aspect of changing a hub is getting a socket that you can get onto the four spindle to hub bolts.
I'll attempt to attach photos of the socket I used. More grinding on both ends would be beneficial.
The highest quality non Bobcat replacement hub appears to be the ACDelco 515110/515111 option. On paper it is listed as
"Gold" as apposed to "Original Equipment" , but I don't know that it is just not marketing.
2016 Nissan Altima 2.5 Sedan (A55853)
2016 Nissan Altima...
Rigid Wet Dry Vac (A54865)
Rigid Wet Dry Vac...
2018 WACKER NEUSON RTSC3 ROLLER (A52576)
2018 WACKER NEUSON...
2016 Godwin CD150M 6in Dri-Prime Pump S/A Trailer (A51691)
2016 Godwin CD150M...
2014 Peterbilt 384 T/A Wet Kit Day Cab Truck Tractor (A51692)
2014 Peterbilt 384...
2017 Ford Explorer AWD SUV (A53424)
2017 Ford Explorer...
