Front Weights
   / Front Weights #1
JagAlfaOwner
Roanoke, Virginia
New Holland TZ24DA
I have a TZ25DA. This past snow fall I used the rear blade to "push" the snow off my drive. I found the front to be very light and little to no help in traction. I got stuck several times where the there was not any snow under the front tires and they just turned, not enough weight to pull. How much weight and where do I get them for the front? The tires are filled but that is insuffcient.
Al
   / Front Weights #2
If you do not have a FEL, then you can get a front weight bar and handle weights from your dealer for the TZ25. I have a TZ25DA with a FEL and woods SS52 blower on the rear. Keep in mind, the front tires are small. That is just their nature. However, I leave the loader on for weight to help. They still spin on occasion, but it always gets the job done. I live in the WNY snow belt and I am impressed with the snow this combination will blow.
Ford F550 Dump Truck (A47384)
Ford F550 Dump...
2015 PETERBILT 365 (A52472)
2015 PETERBILT 365...
2011 Ford F-150 4x4 Ext. Cab Pickup Truck (A50323)
2011 Ford F-150...
2015 JOHN DEERE 310K BACKHOE (A51406)
2015 JOHN DEERE...
2008 Ford Crown Victoria Sedan (A51694)
2008 Ford Crown...
2012 TROXELL COMPANY  130 BBL VACUUM TRAILER (A52472)
2012 TROXELL...
