rbargeron
Elite Member
I've used a rear-mount backup snowblower for a few years. Except for having to turn sideways in the seat, I like how the rear-mount works. I even made a drag blade setup for it last year.
This year an Erskine front-mount sorta fell in my lap so I've been using that one and trying to decide which is better. So far I can see each has its advantages. I think the backup style does a quicker and cleaner job on curved driveways. With the blower close to the rear wheels, it's easier to feed it around corners. Fewer passes are needed to complete the job.
The front go-forward style is definitely easier on the neck and is more convenient to control. On curved drives it seems to work better to cut a straight-ish path thru the middle first, then go back to clear the curves on each side. So it takes a bit longer. The front-mount is easier to sweep sideways in front of double-width garage doors, cutting down on the need for a drag blade.
So the jury is still out - maybe more people chiming in will be useful to others deciding which kind to get.
