Tires Front tires shakey on road????
   / Front tires shakey on road???? #1
NCGMAN
NORTH CAROLINA
YANMAR
Went down the road today to borrow a scrape blade and in third gear going pretty fast (no maxed ) the front tires started wobbling back and forth. Slowed down and they stopped. Speed up;;; wobble....
What is causing this??? What is worn out???? What do I have to order now????
   / Front tires shakey on road???? #2
i am guessing maybe wheel bearing or ball joint
   / Front tires shakey on road???? #3
In addition to check out all the steering components I'd look at tow-in setting and/or bent wheels.
   / Front tires shakey on road???? #4
My 2610D did the exact thing yours is doing...
1st check tow end
2nd check the piviot bearings/pitman arms on top of the front axle.
my brass bushings were worn out...had to pull pitman arms and replace bearings they are cheap mine wore about $7 each
Please note if these bearings are bad and you have a 4X4 tractor the bad bearings will allow the gear housing to be out of allignment and the lower gears in the lower housings will chew up the lower housing seals...
In my case previous owner did not service tractor much and not only were the pivot bearings bad but the pivot itself was worn....too expensive to replace pivot (over $170 each side) so I just pull pitman arms once a year and put in new bearings...
   / Front tires shakey on road???? #5
1st check tow end
Your correct. These problems will also be more noticed with heavier weight on the rear end resulting in a light front end and at higher speeds.
49" X 74" EXPANDED METAL RAMP GATE (A51247)
49" X 74" EXPANDED...
FORREST RIVER CHEROKEE CAMPER (A52472)
FORREST RIVER...
2021 ONYX RX34 ELECTRIC SWEEPER (A51406)
2021 ONYX RX34...
2024 JOHN DEERE 8RX310 LOT NUMBER 77 (A53084)
2024 JOHN DEERE...
49" X 79" EXPANDED METAL RAMP GATE (A51247)
49" X 79" EXPANDED...
