Front tire pressure with loader/??
/ Front tire pressure with loader/?? #1
hunt4570
Super Member
South Carolina
Grand L3540 ,724 loader, bucket, grapple and now forks also! And just for OP.. a pool!
So I just got a new pair of front tires for my tractor. They are 10-16.5 R4 industrial/loader tires going on a Kubota L3540 with a FEL.
My manual says inflate to 20 pounds, my old tires had a max inflation pressure of 45 pounds, these new tires have a max pressure of 75. The tire guy says not to go too low or they could unseat.
What do you guys run for air pressure in your fronts of comparable size??
/ Front tire pressure with loader/?? #2
20 psi is almost definitely not enough. I’d inflate them until they’re satisfactory round with max load on the loader. I don’t think I’ve ever checked my M59 tire pressure but they’re a heavier tire. I ran my L3240 and L3800 at around 40 psi.
/ Front tire pressure with loader/?? #3
40 psi is good.......
/ Front tire pressure with loader/?? #4
I run 50PSI in the front;40 in the rear with the hoe on
/ Front tire pressure with loader/?? #5
I REALLY think you should base your front TP upon the max load you will handle. I have R1's on my M6040. I run 40 psi. That is the max recommended on the side of the tires. I don't think that 45 or 50 psi would be wrong. Pick your heavies load - make a sharp turn - get off and look at the tires. If they are still well seated on the rims - then your are OK. If they are rolling off the beads - I'd up the pressure.
Remember the tires have a max rating of 75 psi.
Yeah, I've been running it at about 30. I got these new ones at 50 for now.
/ Front tire pressure with loader/?? #7
Believe the tire guy....he's your friend. I run my 35 rated 4 ply on the 2400 at 25. I run my 48 rated, 10 ply 12.5x18 on the 6530, at 18. If I am moving hay bales, or full 6' buckets of gravel with the FEL, I'll kick them up to 25. Too rough a ride if they get too high. The 2400 can have a full bucket of gravel and no noticeable sidewall flexing since it's low profile (50 profile ?)...perfect for FEL work. The 6530 has taller sidewalls (78 profile ?) and shows some slight bulging loaded, but being 10 ply I don't worry about it even though they are bias ply.
The sidewall usually references the max pressure and the load carrying capacity at that pressure. You pump those suckers up to max pressure, like you have to run your radial, metric, truck tires, and you'd need the seat belt to keep you in the seat...just look at the rating x 2 and the weight of your machine.
/ Front tire pressure with loader/?? #9
In order to work with the four wheel drive and not destroy the drive line the front pressures need to matched to the rear. I typically recommend picking up the largest load and check the squat of the fronts and attempt to remove it with air pressure but not go over the recommended pressure. Then you will probably have to adjust the rears to compensate for the possible change in height of the fronts to give you easy dis-engagement of the four wheel drive on hard surfaces. That will reduce your drive line tension or windup or down on the drive system.
/ Front tire pressure with loader/?? #10
NO it doesn't read your owners manual ...... Even my pickup 4x4 has different tire pressure front and rear.......
Yup, mine too.
I would hate to try to put 75 pounds in my rear tires!!! The weight is on the front squashing the front tires, if anything it is lightening the back end!
/ Front tire pressure with loader/?? #12
I put the PSI that is on the sidewall of the front tire for loader work..... Like a normal vehicle tire, they are rated for so much load at a certain PSI. The rears can get by with lower pressure.
/ Front tire pressure with loader/?? #13
I have 35 psi in my fronts and 15 in the rears with chains on all 4 corners.
/ Front tire pressure with loader/?? #14
I run enough air pressure to avoid rolling the tires off the rim, my R1 fronts are at 20-30 psi depending on whats going on,
my rears are seldom over 15 PSI.
One thing to be aware of is that many rims have a maximum pressure rating also,
when you go up to a heavier tire the tire could have a higher rating then the rim you have it mounted on.
/ Front tire pressure with loader/?? #15
I run 40 psi front and 15 rear (rears are loaded)
/ Front tire pressure with loader/?? #16
I’ve weighed my Kubota L6060 at local scales with loader full. The weight per tire exceeds the maximum tire rating so I run the max pressure. I previously had a L5740 and loaned it to a relative to clear hunting lanes. He ran both fronts off the rims. My tire guy had a pair of very high load capacity tires available he sole me for half price as the company he stocked them for had gone out of business. I had the dealer switch them onto my L6060 when I traded.
My large ag tractor with loader has 3500 pound per tire load rating but loader capacity is 7700 pounds. Obviously greatly overloaded. However the Tire and Rim Association standard says this ag tire can be used up to 170% of max load rating when used at speeds below 5mph.
Bush Hog 2615 (A64911)
2018 DODGE RAM 5500 FLAT BED TRUCK (A65643)
2018 DODGE RAM...
2007 PETERBILT FLAT TOP SLEEPER  385 (A67714)
2007 PETERBILT...
2015 BIG TEX T/A UTILITY TRAILER (A67714)
2015 BIG TEX T/A...
3pt 8' Box Blade (A64912)
3pt 8' Box Blade...
GAS CYLINDER TRANSPORT BED (A67714)
GAS CYLINDER...
