Chains Front tire chains on 4210 with R4s dont fit
   / Front tire chains on 4210 with R4s dont fit #11
JB4310 said:
I was thinking about the same set up as yours with front chains, do you only have them on the fronts or on the rear also? at first I thought the 3 link spacing was the way to go, but after seeing yours I think 1 link spacing would be better.
I have a 4310 with R4's and it looks like there wouldn't be a problem with clearance, did you have to reverse your rims, yours tires look to be about the same size as mine.
I do loose traction some times on steep drive even with 4x4 so I thought a little help up front would be enough, as opposed to the cost and work involved with rear chains.
Sorry for hijacking your thread jdgreg.
I have chains front and back: front wheels normal mounting, rear wheels reversed for the small but just enough extra clearance. Rear chains are H pattern to keep then from falling in between the treads. It is easy to install the rear chains but they were expensive.
See http://www.tractorbynet.com/forums/showthread.php?p=784375#poststop
UNUSED FUTURE XJ5T HYD THUMB CLAMP (A57193)
UNUSED FUTURE XJ5T...
KENMORE WASHER & DRYER COMBO (A57192)
KENMORE WASHER &...
2012 International 4300 Reefer Truck (A57024)
2012 International...
golf cart (A55787)
golf cart (A55787)
2024 ArmorLite Aluminum End Dump Trailer (A55315)
2024 ArmorLite...
2020 DRAGON ESP...
