Front tire chain l4610
   / Front tire chain l4610 #1
donovansn585
What's everyone's opinion on running tire chains on the front of a kubota l4610 I know it's bad on smaller tractors but how about bigger ones?
   / Front tire chain l4610 #2
Not recommended by the manufacturer. Larger agricultural tractors have heavier front drive components that will better stand up to the kind of wear and tear involved with using chains. Sure you "can" do it, but it's probably going to put a lot of stress on components not built for that kind of operation, even on tractors the size of an L4610 (great tractor, by the way!). Some TBN members that do winter log hauling in Canada and New England operate pretty successfully with rear ballast and chains for traction. Is that an alternative you've considered?
Ya I ran rears on my b7800 I just sold funds are a little low at the moment so just trying to figure out what to do until I get more cash
   / Front tire chain l4610 #4
I used chains on all four wheels on a Kubota B7100 HST. MAde a big difference in mud or snow. Didn't notice any negative effects.:D
   / Front tire chain l4610 #5
I ran chains on all four on my little Ford 1700 in the winter. Never noticed an ill effects.
   / Front tire chain l4610 #6
Tire chains provide a grabbing traction effect which is hard on front axle components.
Once you break something in the front drive line you will feel the $ pain.
Consider screw in tire studs. Put them in in the fall and remove in the spring.
Since they are on each tread bar their tractive assist is much smoother and less aggressive than chains.
Tractor Tire Studs - Tractor Ice Studs - Tractor Snow Studs | Maxigripstore.com
Dave M7040
4 BRIDGESTONE 11R24.5 (A50854)
4 BRIDGESTONE...
2016 WITZCO RG-35 RGN LOWBOY TRAILER (A50459)
2016 WITZCO RG-35...
2006 INTERNATIONAL 4300 DT466 SBA 4X2 BUCKET TRUCK (A51406)
2006 INTERNATIONAL...
1240 (A50490)
1240 (A50490)
2011 FREIGHTLINER CASCADIA (A50854)
2011 FREIGHTLINER...
2024 AGT INDUSTRIAL HR-230 3-WHEEL LOADER (A51242)
2024 AGT...
