Front three point hitch
/ Front three point hitch #1
rScotty
Super Member
Rural mountains - Colorado
Kubota M59, JD530, JD310SG. Restoring Yanmar YM165D
Does anyone have experience using implements on a front three point hitch?
I've got a Kubota with a quick-detatchable FEL bucket and it came with a front three point conversion plate.
I meant to mount a rock rake up there but haven't gotten around to doing it. Anyone else try this sort of thing?
rScotty
/ Front three point hitch #2
Sounds like a rock rake would work on the FEL. Never tried it but thought about welding some brackets on the bucket to see. I didnt know that they made a QA plate just for that purpose. I have seen post here on TBN where they used a boom pole attached to the FEL. I suppose about anything would work if it didnt require too much pushing side pressure. Might be a little hard to steer if using something like a straight blade with side to side pressure.
/ Front three point hitch #3
With the hitch that far in front of the front axle it might be hard to deal with any uneven ground.
/ Front three point hitch #4
I mounted a 3pt QA on the FEL. Have used a landscape rake and boom pole on it. Allows me to rake a site without having to take BH off. Weight of attachment limits how big I can use.
/ Front three point hitch #5
I think other than Boom pole or rake that front 3PT use specialized equipment, I did see a V hay rake and big round baler on a JD monster out west years ago whole trucking. It was on a 3PT mounted on the tractor.
/ Front three point hitch #6
rScotty
I used a boom pole to raise my windmill tower -21'
The Bobtach compatible bucket mount is more useful than using 3pt equipment. Skip the 3 pt and focus on the skidsteer mount. Right now I'm building an offset mount for my hydraulic post hole digger. The offset puts the auger tip off to the right side so I can see it.
/ Front three point hitch #7
rScotty
I also made a forks attachment that fits both Bobtach and also 3pt quick hitch.
2018 GENERAC MOBILE PRODUCTS  MTL6S (INOPERABLE) (A67714)
2018 GENERAC...
HYDRAULIC FLUID TANK (A67714)
HYDRAULIC FLUID...
MI-T-M HDS-3005-Z004 PORTABLE PRESSURE WASHER (A65054)
MI-T-M...
2018 JOHN DEERE 350G LC EXCAVATOR (A65056)
2018 JOHN DEERE...
LINCOLN ELECTRIC POWER MIC WELDER SETUP (A67714)
LINCOLN ELECTRIC...
2023 Kubota Z781KWTI 62in Zero Turn Commercial Mower (A66734)
2023 Kubota...
