Front snowplow bracket help
   / Front snowplow bracket help #1
hazmat
Elite Member
West Newbury, MA & Harrison, ME
Kubota L5460HSTC
Hey gang,
Well After craning my neck & hiting the fence again, I've decided that the rear blade has got to go.
I've located a 6.5' plow & A frame at the junkyard for $100. I'm picking it up tonight.
I plan on mounting it to the tractorframe ala <A target="_blank" HREF=http://www.tractorbynet.com/forumfiles/5-102270-plowpic1.JPG> Beenthere's Western Front Plow </A>
Here's a close up of his<A target="_blank" HREF=http://www.tractorbynet.com/forumfiles/5-102372-Snoplow.JPG> mounting bracket </A>
Question for Beenthere or others:
How high off the ground should the pins for the A frame be? Should the A frame be parallel when the plow is on flat ground? Or at an angle? (plow side down?)
I assume it should be close to parallel so that when the plow is angled, it keeps better contact with the ground.
Another question, how much lift & "drop" should I try to get? I've noticed that most truck plows don't lift off the ground very much, 6-8". How much should will they drop below grade when cresting a hill?
Thanks in advance for your help. I'm looking forward to this "engineering exercise"
   / Front snowplow bracket help #2
Haz ,
Did you fab the mounting bracket yourself ?? or did you purchase it somewhere ?? I am in the process of getting a 7' plow with A frame and can not decide whether to fab a mount inside the bucket for the plow or take the approach you did ....
Mark
   / Front snowplow bracket help #3
What you're calling the "mounting bracket" is technicly called the "Quadrant" in the snow plow business.
Proper mounting height is determined by setting the plow on a flat surphace, with the pushing machine, and orienting the A frame so it is level. This will give you the best pushing orientation for the blade.
If the A frame runs downward from the Quadrant to the blade, the blade will dig into the pavement, and is more apt to tip unnecessarily.
An A frame that runs upward from the pushing machine to the blade will work almost as well as an A frame that is level.
Naturally, no A frame will ever stay level when plowing, but if you start out with a level install, chances of proper blade orientation to the snow & pavement are best.
Mark,
I haven't fab'd anything yet. The picture is a quadrant that Beenthere had fabricated.
I'm working out the details on mine now & am going to have a buddy weld it up for me in exchange for a case of frosty beverages.
The reason I am mounting to the tractor frame instead of in the bucket is to keep the overall length of the machine down. I've got a fence that runs along part of the driveway near the garage, protruding tractor implements have a bad habit of hitting it. Also I should be able to add power angling in the future.
Too bad this project won't be done by Thursday. 6" of snow is predicted.
Franz,
Thanks for the info. I'm a big fan of proper terminoligy, just didn't know what it was in this case. Saves alot of aggravation if the person you are communicating with has a different opinion as to which part is the doo-hicky.
I'll lay the plow out on the garage floor & base my measurements on that.
Here's a pic of my quadrant. It is a work in progress.
   / Front snowplow bracket help #7
How will you deal with the trip springs? I assume they are sized with the idea that a truck will be pushing the blade or doesn't the vehicle doing the pushing matter?
<font color=blue>How will you deal with the trip springs? I assume they are sized with the idea that a truck will be pushing the blade or doesn't the vehicle doing the pushing matter?</font color=blue>
I hadn't thought of that. I just got a lead on another plow: 6' off a geo tracker. I'm going to check that out tonight. It may be a better match for little blue.
I'd assume that the springs are matched to the plow. The rear blade I'm using now is fixed, so I shouldn't do anymore damage to the tractor than the rear blade. I'm mounting to the frame & not the FEL. I have a gravel drive & no curbs which also minimizes impact potential.
   / Front snowplow bracket help #9
Haz ,
I hear ya when it comes to welding everything together. I do not have any welding equipment and will have to work out the same "work for beer" situation as well.
Is it a matter of using the existing hydr for the lifting and lowering of the plow ?? Just as you would the loader , as well as the power angle just like you would curl and dump ???
I heard of that same amount 6" for the Southern NH area as well.
Mark
<font color=blue>Is it a matter of using the existing hydr for the lifting and lowering of the plow ?? Just as you would the loader , as well as the power angle just like you would curl and dump ??? </font color=blue>
Thats the plan. I'll probably hold off on the angle for now to save some $$$.
2012 Ford Fusion SE Sedan (A51694)
2012 Ford Fusion...
2017 Ford Explorer AWD SUV (A50324)
2017 Ford Explorer...
KMC 5610 (A53084)
KMC 5610 (A53084)
2015 Kia Cadenza Sedan (A50324)
2015 Kia Cadenza...
Yale 3,500lb Electric Forklift (A51691)
Yale 3,500lb...
2013 ISUZU NPR STAKE BODY TRUCK (A52577)
2013 ISUZU NPR...
