Buying Advice Front snowblower
/ Front snowblower #1
sandalwood
New Brunswick, Canada
L5460 Kubota
Anyone using a Kubota front snowblower model L4474 or L4485?
Looking at blower specs, L4474 only has a 20 inch impeller (fan) size compared to 26 inch for L4485.
A 20 inch impeller seems kind of small for a 74 inch blower and would seem to run the risk of being overwhelmed by quantity of snow it would be fed by auger.
Anyone with any experience with either of these models?
Thanks
/ Front snowblower #2
That is a big difference in diameters.
Any info on the tip velocity of the impellers at the same PTO speed?
Do they run at the same PTO speed?
Do both blowers have the same drive ratio off the PTO, or does the 20" have a different ratio to match the tip velocity of the 26" at the same PTO speed?
/ Front snowblower
No mention of tip velocity on Kubota site, only that both size blowers have impeller rpm of 545.
These snowblowers are manufactured by RadTechnologies for Kubota with no posted specs of their own web site.
/ Front snowblower #4
So tip velocities would be:
545*(3.14*20)/60 = 570 in/sec = 47.5 ft/sec
545*(3.14*24)/60 = 685 in/sec = 57.1 ft/sec
Kinetic energy is proportional to velocity squared, so (57.1^2)/(47.5^2) = 1.44.
So the 24 inch machine should be throwing the snow with 44% more energy.
Seems like a big jump for increasing width from 74 to 85 inches.
If I had the HP to run that larger blower, I'd definitely be favoring that one.
But an 85 inch thrower seems like a lot to ask a 23 Hp PTO to run (assuming it's for the B3030).
Is your tractor HST or gear?
/ Front snowblower
Thanks for the information, it explains well the difference between 2 impeller sizes.
I went back to the Kubota.ca site and looked again at the web page for L4474 blower. In one place they list impeller diameter as 20" and another place as 26" diameter. I am assuming that 20" is a typo.
I'm thinking of upgrading the B3030 (23 hp pto, rear blower) to L5460 (46.5 hp pto, front blower) and the L4474 is for the L5460.
/ Front snowblower #6
L5460 with a 74" front blower sounds like a great combination.
Just double check your tire track width - especially if you're planning on getting wide tires like R4s or turfs.
Make sure you're getting at least a few inches wider than your track width.
/ Front snowblower
According to Kubota brochure, tractor supposedly 67 inches wide and blower 74 inches. I just don't know if reported tractor width is with R1 or R3. I am planning on R3s.
/ Front snowblower #8
I've been trying to figure what tire they figure the 67 from? Does anyone know the true numbers difference R1, R3 and R4?
/ Front snowblower #9
The R1s come with wheels that can be set at 4 different widths, not sure if the R2s, R3s & R4s have this adjustable width or not.
I've also noticed some very wide R1s - don't know what they're called, but they look great.
Best way to find out might be to take a tape measure with you and measure some tractors at a dealership.
Oh - and check the cab/folded ROPS height vs barn door height, if you're keeping it inside.
I had a moment of panic after signing papers for the L3240, but it fits under the garage door with 3" to spare.
2016 KENWORTH T270 SERVICE TRUCK (A62130)
2016 KENWORTH T270...
ROLL OF 6' CHAINLINK FENCE (A62131)
ROLL OF 6'...
2018 KENWORTH T880 FLATTOP DAYCAB ROAD TRACTOR (A62130)
2018 KENWORTH T880...
UNUSED WOLVERINE TDB-11-66W 66" QUICK ATTACH BKT (A62131)
UNUSED WOLVERINE...
UNUSED ATS EJ 11000 ELEC.JACK (A62131)
UNUSED ATS EJ...
25026SFL (A61569)
25026SFL (A61569)
