Front Remotes?
   / Front Remotes? #1
Jsheds
Eastern PA
I want to adapt my power angle snow plow to my 14LA loader, but am wondering how to get hydraulic power to the fron of the tractor. Does NH have an option for front hydraulic remotes (I'll still need all the loader functions), or do I need to run hoses from my rear remotes to the front of the tractor. I'd prefer to do this with steel lines if possibble. Any ideas?
Thanks,
Jim
   / Front Remotes? #2
I think you could use an electric diverter valve off of the curl circuit, but I'm not 100 % sure. By doing this, you hold the button ( which electrically shifts the diverter valve ) and then your loader control ( curl ) will angle the blade. Let go of the button, and your back to normal. Sounds simple...probably isn't /forums/images/graemlins/grin.gif
If I'm not mistaken, many folks just do away with the curl for the season and use those fittings for the angle.
   / Front Remotes?
That would make for a clean installation, which is what I'm looking for. I need to go to the NH dealer and see how they run the hydraulics for the NH snowplow, but the dealer is about an hour away and I havn't had the chance to take the trip. Fortunately, the weater channel hasn't predicted any snow for PA in the near futre.
   / Front Remotes? #4
I merely ran a set of hydraulic hoses (14') from my rear remote, under the tractor being sure to stay clear of any moving or hot parts, up to my grill guard. I then connect them to the 3' pigtails coming off my snowplow. Works great. I still haven't taken them off they are just wrapped around the grill guard. I may well just leave them there.
Toro Workman Low Profile Spray system 200 (A50322)
Toro Workman Low...
2013 Chevrolet Caprice Sedan (A50324)
2013 Chevrolet...
1972 Baker 30ft Pole S/A Towable Trailer (A51694)
1972 Baker 30ft...
2013 Ford F-250 XL (A50120)
2013 Ford F-250 XL...
Crosley 10ft Hydraulic T/A Dump Trailer (A50323)
Crosley 10ft...
2010 Ford Fusion Passenger Car (A51694)
2010 Ford Fusion...
