Front Push FEL vs. Mid Mount
/ Front Push FEL vs. Mid Mount #1
mark4Jesus
Sale Creek, TN
2021 Branson 2610h
I am new to TBN and am looking forward to learning much from everyone's experiences. I am looking at Bush Hog FEL's for my Kubota B2150. There is a Front Push model and a Mid-mount model. What is the difference and advantages of each? Thanks!
/ Front Push FEL vs. Mid Mount #2
I just installed a midmount type on my tractor. I have had the front push type in the past. The midmount is a very stout system. It has several mount points including attaching to the rear axle. It is made of 3/4" steel. I am very impressed with mine so far. It mounts and dismounts quick and easy. I can install it almost as fast as my box blade on my 3 point. I have no regrets with getting it instead of the other type.
/ Front Push FEL vs. Mid Mount #3
If the midmount also ties to rear axle, it would be best for tractor. Some larger tractors having midmount loaders without rails to axles crack at speed transmission housing. Possibly from abuse, but it happens.
Hey Reed, being an ex-dealer, which of the 'also ran' foriegn CUTs do you reccomend? I see you own Iseki. Is it happenstance or do you prefer it over Mits, Yanmar, etc? Is there any customer satifaction, call back, warranty claim info available for CUTs?
I called Bush Hog and was told that the front push FEL was designed for older tractors. Their mid-mounts were designed in the late 90's, my B2150 is a '91 model. Bush Hog rep said that the front push was the one for my tractor, the mid-mount would not work on it.
Small Indian Statue (A64557)
Small Indian...
2004 IC Corporation 3000IC School Bus (A64194)
2004 IC...
2014 KENWORTH T370 ROAD TRACTOR (A64280)
2014 KENWORTH T370...
2016 KUBOTA SVL90 SKID STEER (A65053)
2016 KUBOTA SVL90...
2017 TROXELL 150 BBL ALUMINUM VACUUM TRAILER (A63569)
2017 TROXELL 150...
Welcome to the Ranch (A64557)
Welcome to the...
