front pto
/ front pto #1
ricknrandy
Yanmar 155D
I need the splined sprocket that mounts between the crankshaft and the front pump with the double chain. This is the sprocket that goes on the splined shaft that bolts to the crankshaft and connects to the extension shaft with the double chain. Any ideas where I might find one?
/ front pto #2
Welcome to TBN!!
Since you have a Yanmar tractor, I suggest you post your question in that forum. If the part is available, I'm sure one of those folks can give you some good sourcing info.
/ front pto #3
It's tough to help without the make, model and year of the tractor in question.... Photos are a great help also.
/ front pto #4
I'm not sure what your sprocket is like, but I replaced the chain coupler components in my YM240 with parts from surplus center. Mine weren't splined, though. On the pump end, there was a 3/4" keyed sprocket. The shaft in between was solidly welded to two sprockets, and there was a hub that bolts to the crankshaft with another welded pulley. As others have mentioned, some pictures and dimensions will really help.
Yamaha Golf Cart (A57149)
Yamaha Golf Cart...
UNVERFERTH PERFECTA II 18' FIELD CULTIVATOR (A63291)
UNVERFERTH...
2022 Bautista Welding and Custom 40ft. 10 Ton T/A Gooseneck Flatbed Trailer (A61573)
2022 Bautista...
17in. Tooth Excavator Bucket (A64194)
17in. Tooth...
PALLET FORK ATTACHMENT FOR MINI SKID STEER (A61572)
PALLET FORK...
2023 CATERPILLAR 289D3 SKID STEER (A62129)
2023 CATERPILLAR...
